Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - roller cam vs Hyd. flat tapper cam
  #29 (permalink)
Old 04-10-2012, 02:08 PM
Dannyringo Dannyringo is offline
Originally Posted by 66GMC
Excellent point in regards to reading OLD information.
Using RotellaT 15w40 diesel oil (SH) *used to be* a viable work-around, before they legislated the required use of catastrophic converters on diesel engines too.
After doing my research, I see you had the wiped lobe syndrome on a 454 build...Did you ever go with the roller cam in that motor, or did you do another Hyd. flat tappet cam after your heart was broken?
