roller clutch - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2012, 01:15 PM
roller clutch
I broke my automatic trans. rear roller clutch,or rear planetary flange, so i lost 2nd and 3rd gears,just have 1st and reverse...But i can start in 1st/low power up to about 15/20 mph and manually shift into 2nd then 3rd/drive ,and head on down the road...But if i slow way down/or stop sign, i have to shift back into low and start over again,,seems to work fine as long as i shift it like a stick shift...Q. how safe is this,or whats the chance of having trans.locking up or screwing up...or is the broken clutch part out of the way ,from doing damage..it makes no noise at all,other than when i slow down in 2nd or 3rd,it whines like its free spinning....thanks...georgegouvas2@hotmail.com
Old 10-27-2012, 05:31 AM
SSedan64's Avatar
May want to include what Trans you're talking about.
Old 11-01-2012, 09:08 PM
sedan 64
thought we had psycic powers on this site lol
Which way does the low reverse roller clutch assembly go? old yukon Transmission - Rearend 6 04-22-2011 06:55 AM
TH350 roller clutch problem 1969ChevelleGuy Transmission - Rearend 3 04-09-2011 04:31 PM
700R4 rebuild with wider low reverse roller clutch qwkswede Transmission - Rearend 17 01-04-2010 06:29 AM
TH350 Roller Clutch help Chris_K Transmission - Rearend 7 10-16-2005 08:44 PM
th350 low roller clutch and 700r4? Tissue Transmission - Rearend 4 05-16-2004 11:23 AM
