roller flat tappet lifters!!!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2007, 06:32 PM
383silverado's Avatar
had jeff from koerner racing fix my aluminum vortec base intake for my 97 silverado and found out he make roller flat tappet lifters
http://www.koernerracing.com/flatroller.htm
here's an article on roller vs flat tappet
http://www.revsearch.com/dynamometer...lattappet.html
Old 06-21-2007, 06:43 PM
Jmark's Avatar
Interesting idea. Not sure if "roller lifter" fits it but does show promise. Keep us informed on further progress.
Mark
Old 06-21-2007, 08:01 PM
Bumpstick's Avatar
Hammer and a torch
Hummm...? Could be the answer to flat cam lobes because of the removal of zinc in our oils...?
Like to see the cost and long term durability...?
Old 06-22-2007, 03:03 PM
about $700 for a set of 8 they're in testing stages right now jeff said he will keep in touch so will post more info as it is available
jeff also said he uses brad penn racing oil in flat tappet engines to reduce friction he is a distributer for them
http://www.bradpennracing.com/
here's some more info on another guy making the same type of lifters
Schubeck rewrites the Book on:
"The Care and Feeding of Flat Lifters!!"
The Discovery of a Space Age material used in the production of Schubeck lifters, not only raised the bar for higher competitive achievements, but justified the reason for rewriting the book on "The care and feeding of flat lifters". All the rules handed down through the years, deemed necessary to make a flat cam and lifters survive, no longer apply.
Rules such as:"Flat lifters need a tedious break-in process in order to survive" and
"A lifter should never be separated from the mated cam lobe after break-in", not any more.
Now using "Schubeck composite flat lifters". You just install the lifters on your new or used cam, raise the spring pressure, if you desire and go to the races. You can also experiment with different cams as often as you like, using the same Schubeck Lifters, again and again.
Soon you will disregard the rules that we were all taught over the years. Yes, you will develop new confidence that they no longer apply. The're will be, No Break-in, No Lifter Wear and No Cam Wear. Go to the track with your mind on more important things.
i'm just using his lifters as an example ok because i read what GUY HILTZ SAID
QUOTE ( I've tried adding a company review to the appropriate spot a couple of times,but have been unsucessful.This is a word of caution to anyone who may be interested in purchasing anything from Schubeck Racing,stay away from them,they take your money up front and dont deliver the goods.It is impossible to contact them,they dont return emails & they dont answer the phone.Getting a refund is next to impossible.
STAY AWAY FROM SCHUBECK RACING !!! ) QUOTE
Schubeck Racing
http://www.schubeckracing.com/new2/i...position=61:53
solid flat tappet v/s hydraulic roller 406 ss monte Engine 8 10-31-2006 08:29 AM
Hyd Roller lifters underdog305 Engine 7 10-13-2006 08:42 PM
What is the BIG difference between flat tappit and roller cams ozzt Engine 4 01-27-2005 08:06 PM
roller lifters???? chevyelc81 Engine 5 06-18-2002 06:05 PM
engine rayjo Engine 3 04-28-2002 08:22 AM
