We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 06-13-2004, 09:05 PM
84Z 84Z is offline
Gas Raper
Roller lifter on non roller cams?
I'm haveing a big debate with my friend, and decided to settle it once and for all. So:
Can you use roller lifters with a non roller cam?
Thanks for replys
Old 06-13-2004, 09:27 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
NO!.......
Old 06-13-2004, 10:02 PM
killerformula's Avatar
killerformula killerformula is offline
killerformula's barnstar
Wiki editor
Last wiki edit: Carburetor
Wiki Edits: 3
I guess bob is probably right, I've never thought of it before. What would be the point of spending the money on the roller lifters anyway? The cam isn't ground to take advantage of them even if you could use them. Despite the errors in popular belief, roller cams don't make more power because of friction losses.
K
Old 06-13-2004, 10:52 PM
NorthStar NorthStar is offline
NO! Is the short answer.
No because flat tappet cams are ground with a very small amount of taper to make the lifter rotate, lifter is also specially ground with a small crown for same reason.
Roller cams are ground with zero taper and rollers are perfectly round with no crown no taper.
Roller cams use a retainer plate to keep them from moving forwards, flat tappet cams have the tapers ground so the cam is being pushed back against the block.
Put roller lifters on a non roller cam and it wont last very long. Thats the somewhat long answer.
Old 06-14-2004, 12:03 AM
87442lover 87442lover is offline
Grumpy
No, the lobes of a flat tappet camshaft are different, they are narrow compared to a roller cam. The side of the roller lifter contacts before the roller does if tried with a flat tappet camshaft.
Old 06-14-2004, 12:28 AM
84Z 84Z is offline
Gas Raper
lol, thank you. That shut him up damn quick.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
