Roller Lifters - standard cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2006, 08:10 AM
ckucia's Avatar
I did some research on this on the web, and came up with conflicting opinions.
Lets say I have an oddball engine with an OEM cam and regular hydraulic lifters.
Just for example, lets say I found a set of OEM or aftermarket roller hydraulic lifters that will fit the bores (perhaps with some slight modification) and work with the lifter oiling system.
Can I use these roller lifters on a non-roller cam? Can I upgrade to an aftermarket non-roller cam and use the roller lifters?
If this could be done, can the roller lifters on a non-roller cam handle stiffer valvesprings easier than standard hydraulic lifters without premature wear?
If not, would there be any advantage/disadvantage to running roller lifters on a non-roller cam (not counting the expense)?
Old 01-26-2006, 08:16 AM
Infomaniac's Avatar
Twin Turbo Drag Boat
Last journal entry: Random In Progress Shots
You cannot run rollers on non roller cams.
The lobes are not the same.
You can physically put them on but it will not run very well at all.
There is a reason for the differences. Just buy yourself a roller cam.
Old 01-26-2006, 08:27 AM
ckucia's Avatar
Unfortunately, roller cams not available, other than having one custom made.
Old 01-26-2006, 08:29 AM
bigbadbowtie's Avatar
Bottle Fed
few reasons whey I know you cant,
Roller cams (in most cases are billet) so they can take the higher spring pressures. Roller setup on a cast cam would eat up in short order.
Flat tappet cams have a taper to each lobe so that the lifter spins in the bore.This is also what keeps the cam from walking.
Roller cams do not, they use a button to keep them from walking.
Old 01-26-2006, 09:02 AM
ckucia's Avatar
The differing materials was the biggest issue that I found.
It seems a little counter-intuitive. Sure, the rollers are harder than the cam, but they're rolling. Seems like there ought to be a lot less friction and wear on rolling surfaces, even with two different hardness on the materials, than a sliding surface of identical materials.
Is it still a problem with stock spring pressures? I'm primarily interested in longevity, with the ability to boost the spring pressure just being a bonus, if it were even possible.
A custom made cast cam is pretty affordable, but a custom made roller cam is out of budget. I'm not looking for an aggressive grind or ridiculous spring pressures - more interested in eliminating a source of friction.
Old 01-26-2006, 09:48 AM
StevenC's Avatar
there is a taper in the lobes which will not work good with the rollers.
Old 01-26-2006, 09:49 AM
A "custom" roller shouldn't cost anymore then a shelf roller.
Old 01-26-2006, 09:59 AM
rollers
Ckucia first I will say it won't work. Second is why, anything you gain with roller friction you loose if you add stiffer springs more or less. The reason for stiffer springs and roller cams are mainly higher lift,longer duration,and higher rpm without float. The ramps for the lifter open and close on a roller are ground completely different on a roller because of the roller. Rollers themselves don't make power thy only allow for better cam grinds. Plus if you look at the length on the lifters the roller is likely taller and would cause geometry problems.If you try it, go ahead and get a second job because if you can't afford a custom roller that new engine will set you back just a little more than the cam. If you can come up with an old roller that will fit you block it can be reground comp. has done a few for me it saves a $100.00 to $150.00.
Old 01-26-2006, 10:07 AM
Infomaniac's Avatar
The shape of the lobes are no where near the same dude. It's not a matter of material etc.
It's the difference between a flat surface or a round surface riding on the lobe. Completely different shapes.
Old 01-26-2006, 10:34 AM
ckucia's Avatar
From what I've read on the web, there is a significant material difference between roller and non roller cams.
Roller cams are manufactured from steel billet, non-roller from cast iron.
For a non-standard engine, there are not billet "blanks" for the cam grinder to use to make a roller cam, so roller cams aren't offered.
I don't think lobe profile is all that much of a concern, as a custom ground cast iron cam can be had for a fairly reasonable price - just about every engine out there has cast iron cam "blanks" available.
I guess my question, more specifically, was if the roller cams are billet because of the billet roller, or are they billet because the roller allows much higher spring pressures and aggressive profile, which requires a harder material to prevent cam lobe wear.
I'm not particularly interested in higher pressure or aggresive profile. I'm not opposed to having a custom-ground cam made that would match the stock flat-tappet profile to a roller lifter. I'm trying to build something bulletproof, not necessarily push the performance to the edge.
Sure, the ideal solution would be a custom-ground steel billet roller cam. The prices I've seen start at around $2000 and go up from there - and this is for something that may require some expirimentation to get right.
Old 01-26-2006, 11:10 AM
engineczar's Avatar
The big question is what type, year, and size engine are you building? You keep referring to a non-standard engine.
Old 01-26-2006, 11:11 AM
Here's an article comparing cams...
http://chevyhiperformance.com/techarticles/95258/
What kind of engine are you working with? I can't imagine that it costs $2000 for a custom ground cam.
Old 01-26-2006, 11:22 AM
ckucia's Avatar
Engine I'm considering is a Cadillac 425 - same basic block as the 472/500 but lighter.
I found another vendor this morning who can produce custom billet roller cams - they require boring out the cam bearing journals. These are just over $1k and its a custom grind so I could tailor it to my specs. That's a little more affordable - still a lot more than a custom cast cam - but still pricey. I might be able to live with that.
The reason I didn't mention the engine is that I was really trying to find out if the roller lifters on the cast cam were doable with close-to-stock specs. I know most people are going to want to go with a more aggressive lift and/or stronger springs, but I'm sure there are some people who would like the benefits of roller lifters w/o getting too agressive. Just trying to find out if this was doable for all the odd-ball engines out there. In my case, it looks like there is a solution, albeit an expensive one, but that isn't always going to be the case for every engine.
Old 01-26-2006, 11:34 AM
Infomaniac's Avatar
Most hydraulic roller cams are cast iron.
Solid roller cams are steel billit.
And it's mainly due to spring pressures and cam deflection.
Old 01-26-2006, 12:02 PM
Banned
You can run roller lifters on a hydraulic cam, I've done it, however you loose duration when you do it, and besides that, there's really no point in doing it, but whatever floats your boat. This is as old as the short VS long rod argument.
roller cam in an non roller block..is it possible? bigshow2 Engine 5 09-18-2005 08:31 PM
retrofit roller lifters??????? jesse01 Engine 9 08-06-2005 07:45 AM
Can i have my solid roller cam re-ground? shockers69 Engine 1 04-19-2004 08:41 PM
Anything special to put roller cam in 400 block? sb72elcamino350 Engine 1 04-10-2004 12:12 AM
chevy Roller lifters? 87442lover Engine 19 02-21-2004 03:08 PM
