roller rocker 1.5 to 1.6
I have a hydro flat cam 480/492 228/234 @110. What will going to 1.6 do for me? Will I need new rods? I have full roller rockers 1.5 now (trickflow) and they are loud so thinking of going to comp or crane. My heads will go to a 540 lift.
A .480 camshaft with 1.5 ratio rocker and going to 1.6 would be OK :)
Take .480 and divide by 15 ( 1.5 ) = .032 Then multiply by 16 ( 1.6 ) = .512 It would be like having a camshaft with .512 lift. :D |
and you need not do or buy anything else
Loud rockers
I think I would contact Trick Flows Tech dept first,loud being a problem is unusual and needs to be adressed, switching to another brand might be a waste of $$ the gain from upping the ratio won't be noticable anyway.Sometimes increasing ratios can cause pushrod clearance issues requiring some minor machining.Also what valve springs are you running?
just check for spring bind etc.
| All times are GMT -6. The time now is 05:34 AM. |
