roller rocker 1.5 to 1.6 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2007, 02:51 PM
I have a hydro flat cam 480/492 228/234 @110. What will going to 1.6 do for me? Will I need new rods? I have full roller rockers 1.5 now (trickflow) and they are loud so thinking of going to comp or crane. My heads will go to a 540 lift.
Old 12-22-2007, 03:20 PM
A .480 camshaft with 1.5 ratio rocker and going to 1.6 would be OK
Take .480 and divide by 15 ( 1.5 ) = .032
Then multiply by 16 ( 1.6 ) = .512
It would be like having a camshaft with .512 lift.
Old 12-22-2007, 08:15 PM
GoneNova/406's Avatar
and you need not do or buy anything else
Old 12-23-2007, 12:53 AM
JeffB's Avatar
Loud rockers
I think I would contact Trick Flows Tech dept first,loud being a problem is unusual and needs to be adressed, switching to another brand might be a waste of $$ the gain from upping the ratio won't be noticable anyway.Sometimes increasing ratios can cause pushrod clearance issues requiring some minor machining.Also what valve springs are you running?
Old 12-23-2007, 02:50 PM
Originally Posted by JeffB
......the gain from upping the ratio won't be noticable anyway.....
Going from .480 lift to .512 is not noticeable? Really?
Old 12-23-2007, 03:54 PM
JeffB's Avatar
You won't feel a gain of 4-6 HP,remember you won't be changing the duration at all,only the lift factor.
Old 12-23-2007, 04:33 PM
dawg's Avatar
NAVY VETERAN
just check for spring bind etc.
1.5 stock to 1.6 roller rockers? oregon chevelle Engine 9 03-01-2006 12:17 AM
1.5 vs 1.6 roller rockers? Streetmaster Engine 10 09-09-2005 10:27 PM
Which rocker arms 1.5 or 1.6 ratio??SBC batman09 Engine 47 12-04-2004 04:31 PM
1.6 to 1.5 roller rockers-which should i use 65vettestroker Engine 5 11-07-2004 12:24 AM
1.6 roller tip rocker arms? Marcus Engine 2 03-02-2003 09:40 AM
