Roller rocker arm durability, under 7000rpm - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2013, 10:36 PM
4 Jaw Chuck's Avatar
Looking for personal experiences of those who have street driven a brand of roller rockers and can attest to their durability. Obviously a solid cam places more stress on the valvetrain with this style of rocker so I would place more weight on those experiences.
So many choices out there from many different mfgs and quite a few horror stories as well, let's leave the pedestal mount Jesel style models out of this for now as it's out of range for the average rodder.
To be exact I'm looking for a SBC 3/8" post in 1.6 ratio and need a good recommendation from a member of the board who has put some serious street miles on theirs and can say they work without coming apart over time.
It would seem many installs don't have deflectors to keep them and the springs properly cooled and lubricated so I wonder how many of those horror stories are from poor setups.
What say you?
— Han Solo
Old 11-26-2013, 10:57 PM
vinniekq2's Avatar
I have not and wont likely use 1.6 roller rockers on the street,just buy the correct cam to start.
I have used Crane roller (aluminum) rockers on a street driven small block 355 in a 1967 Camaro,that I had for 5 years.(It was stolen) The heads were GM cast iron,the cam was a .505 solid with 315 advertised duration. The car was driven almost everyday. It made 2 long trips(for a bracket motor) from Vancouver BC to Bremerton,with 5.13 gears,,,3700 RPM all the way there,got lost and drove an extra hour.
same car Vancouver to Seattle,both trips included racing and driving home.
same rockers were used when I later got a used roller cam from Richard Johnsons 56 chevy SS 265. I then used 5.57 gears and trailered the car for as long as I owned it.
Many failures,never a rocker arm
I now use Jessel rockers with mixed ratios
Old 11-27-2013, 12:09 AM
Lots of reasons why I want to use 1.6 ratio rockers, primarily I am duplicating the ZZ430 crate motor from GMPP which used the LT4 cam and 1.6 rockers. I already have the proper AL 604 heads which I lucked out on finding cheap.
The GMPP "Hot cam" P/N 846 which was a part of this package has a 0.525" lift with the 1.6 rockers which is max for the stock springs, looked hard for an aftermarket cam that is similar but everything is either way higher or lower lift or too little duration or too much.
I've thought about stepping up to the next level cam P/N 847 but then I need new springs, this is what is used in the ZZ465 crate engine and honestly the car won't need more power for the application.
The car is a FC 1987 Mazda RX7 TurboII with 4.33:1 rear axle, about 2600 pds total. Engine is a late model 4 bolt main Gen I roller block about 10:1 comp with a TH400 trans.
I'm going to use the stock exhaust so it's quiet and a radical cam would give it away, the car will be autocrossed so big cams are useless when precision and a broad flat torque curve is key.
Here's the car, engine will be relocated about 5" rearward with front and mid motor plates.
— Han Solo
Old 11-27-2013, 05:33 AM
Last journal entry: Still running strong
Most aluminum roller rockers that are 1.5 are really 1.6 ratio out of the box, their made like that to account for flex. I don't think you could go wrong with steel rollers rockers. I've had 1.6 roller tipped rockers (Crane) self aligning on my Vortec heads for 5 yrs. now with no problems. Not full rollers but they work an I don't worry about them.
Old 11-27-2013, 05:48 AM
Banned
Who in the hell started this idea that 1.6 rockers are somehow wrong? It must have been some idiot who never built anything besides a stock sbc as there are many many many engines that comes from the factory with other ratios. Also, how is it better to run a steeper love rather than more rocker ratio to achieve the same lift?
As for durability- can't argue with what the general uses in their crate and hot cam packages.
I've logged a lot of miles on Harland sharp rockers myself. Any reputable brand should be fine provided they're installed and oiled properly.
Old 11-27-2013, 11:18 AM
What say you?
The 350 in my S15 has 360,000 miles on a set of 1.6, Jim Miller, Mid Lifts which are full roller trunion and tip in a fat aluminum housing. No failures of bearings nor fatigue issues with the rocker itself. But of course Jim doesn't make these any more.
Bogie
Old 11-27-2013, 11:41 AM
techinspector1's Avatar
Wiki Edits: 326
It makes little sense to use 1.6 rockers on a street motor small block Chevy. Now, if you're talking race motor, great, knock yourself out, use 1.8 rockers if you can make them work. But here on this forum, we're dealing with fellows who are looking for a little more grunt from their street motor, not looking for every last horsepower and making the valvetrain work harder than it has to. We have enough trouble with fragging cams and lifters as it is, without adding fuel to the fire.
A change from 1.5 to 1.6 adds 16% more effort to the cam lobe and the lifter crown for a return of ~10-15 horsepower in most cases. What difference does it make if the motor is making 400 hp or 410 hp? The driver ain't gonna feel it in the seat of his pants anyway.
You do what you feel you have to do and I'll continue advising against higher ratio rockers on street motors, favoring long life rather than extracting every last horsepower from a motor.
The Following User Says Thank You to techinspector1 For This Useful Post:
OLNOLAN (11-27-2013)
Old 11-27-2013, 03:05 PM
For durability/endurance, I always use steel rockers, whether they are Crower, Comp or the long ago Norris. I have never had one fail.
Old 11-27-2013, 03:26 PM
jokerZ71's Avatar
Wrench Turner
I favor a steel or cast rocker as well over aluminum for a street motor as well.A lot of the better aluminum rockers are considerably larger & most require tall valve covers,or'removing baffles.In my case,tall covers won't work unless I wanna get real creative with my A/C,or'do w/o it.
Old 11-27-2013, 03:29 PM
jokerZ71's Avatar
Wrench Turner
Originally Posted by F-BIRD'88 View Post
The Scorpion aluminum roller rockers have worked very very well for me.
The 1.6 's apparently actually check at 1.65:1.
GMPP is switching over to using the LS3 Beehive springs on most all these crate motors now.
I suggest you do the same. GMPP has a retainer for that now too.
Comp 787-16 retainer works too.
You can shim the beehives to adjust installed height and pressure as required.
The beehive springs control the Valvetrain better.
Welcome to Scorpion Performance
When I need a aluminum roller rocker arm this is what I use.
It is important to note that when switching from a stock type rocker arm to a aluminum roller that you look at the pushrod length and rocler geometery/roller tip sweep pattern on the valve tip.
Some rockers have a different relative pushrod seat location/geometry requiring a pushrod length change to get it right.
This modified pushrod seat location modifies the valve lift curve/complex rocker arm ratio curve as the valve actually opens and closes.
So there is more to it than just a raw simple ratio change.
The Scorpion rockers work good.
F'Bird,do you have the part# for the GM retainers?I heard they have em,but,haven't found any.
Old 11-27-2013, 04:29 PM
prostreet6t9's Avatar
Differential/Driveline
What say you?
468 BBC with a 710" camshaft. Spin it up to 7400/7600 on occasion. Street/strip car and has been together for 6 years and havnt hurt anything yet. I used the Crower rockers.
Old 11-27-2013, 06:43 PM
vinniekq2's Avatar
I bought a gen II RX-7 in January 1986.I loved that car,mine was a GXL 2+2. If you V-8 that car take the time to get the weight and balance correct again. Great driving car,only slightly less as good at handling as the 944 turbo and less than 1/2 the cost. I wish my Corvette handled that well.
Old 11-27-2013, 08:34 PM
OLNOLAN's Avatar
Crane gold
This is what I'm spinning 6900. Don't mean to, got the light set on 6600 and the rev limiter on 6900 sometimes I get on the Msd pop pop before I can pull a gear, old fukr, shift stupid. They are 1.6 but its what my cam is specified for. I've thought about backing down to 1.5's because the cam is SO ROWDY, but thats what you get when you run a drag cam on the street. Runs super on the big end, but on the street you have to downshift alot to keep it in the power band. They haven't broke yet with over 5000 miles. ;http://www.summitracing.com/parts/crn-11755-16
Old 11-27-2013, 08:40 PM
roller rockers
had good luck with crane gold rockers.for added reliability i used arp rocker studs
Old 11-27-2013, 11:28 PM
Thanks for the personal experiences gents, sets my mind at ease.
Man those GMPP parts are expensive here in Canada, ordered a replacement intake and exhaust valve today from my local GM dealer. Hold your hats...one of each of the hollow intake and sodium filled exhaust valve totalled $170 before taxes.
I only paid $250 for both heads!
Good thing only one of each needed needed replacing, I could get titanium valves at those prices.
— Han Solo
A Good set of HYD Roller Lifters that can rev to 7000rpm desmosis10 Hotrodding Basics 11 10-07-2012 11:05 AM
Any Advantage With Roller Tip Rocker Arm beertracker Engine 16 09-21-2010 02:54 PM
1.6:1 Roller Rocker arm troubles... Caballerokid Engine 32 05-04-2010 08:42 PM
roller rocker arm ratios 454cutlass86 Hotrodding Basics 8 04-22-2009 09:22 AM
roller rocker arm question savman1 Engine 5 07-21-2007 01:16 PM
