roller rocker arms - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-29-2008, 04:30 AM
roller rocker arms
i want to swtich from the stock rocker arms to the roller rocker arms. so how do i tell what size rocker studs are in the heads either 3/8 or 7/16th and whats the difference between 1.5 and 1.6 ratio i have a Comp cam 292 i have to look up the spec on that.... 350 chevy
Old 02-29-2008, 05:05 AM
DoubleVision's Avatar
The factory stud size is 3/8, 7/16 studs are used mostly on small blocks with heavy duty valve trains that see extreme service or just someone wanting a little more support. The 1.5 ratio is the "factory" ratio, but stock rockers are out to lunch on this as much of them have a ratio of around 1.4
Most cam lifts are given with a 1.5 rocker ratio, by bumping up to a 1.6 you'll add about .030 in lift and around 1 degree of duration. Example if your cam has .500 lift with a 1.5 rocker, moving to a 1.6 bumps it up to .530
Make sure you get a quality name brand set of rockers, cheap brands like proform or Cat, is made off shore and the quality and the ratios aren't up to par. You get what you pay for.
Old 02-29-2008, 06:04 AM
leldai73's Avatar
Its just metal,you're the boss
I'm running Harland Sharp, reasonable price, good quality, and made right here in the USA. not to mention they are a really cool orange color...it was hard to bolt the valve covers back on knowing i would only see those fancy things once in a great while.
Old 02-29-2008, 06:52 AM
roller rockers
whats so wrong with proform products??? they cant be no more junk than the speed-pro pistons that everybody brags on in here...
Old 02-29-2008, 07:52 AM
racecar100's Avatar
If your heads have screw in studs I'd go with 7/16 all the way. It will make you valve train more stable.
I'd go with Scorpion rocker arm. It's made in USA at cheaper cost. We never had any fail yet.
Old 02-29-2008, 08:47 AM
302 Z28's Avatar
Proform cra# is made in China.
Vince
Old 02-29-2008, 08:54 AM
Dugg's Avatar
My compass doesn't point North
Of all the ways there are to spend money, roller rockers is certainly one of them. Not only are they a terrific way to spend money, now you can begin to worry about when one will break - especially if you haven't installed those little screens in your oil return passages to catch the bits.
valve springs, valves, push rods, and rocker arms elcaminodragster Engine 7 01-28-2008 08:48 AM
roller rocker arm question savman1 Engine 5 07-21-2007 01:16 PM
Tightening Rocker arms caminoguy55 Engine 2 03-13-2004 08:05 PM
1.6 Ratio Rocker Arms stfinney Engine 6 11-02-2002 05:55 PM
Roller Rocker arms bigjoedo Engine 1 08-27-2002 05:30 PM
