Roller Rocker arms - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2002, 04:59 PM
Post Roller Rocker arms
Is there any potential problems replacing the stamped rocker rocker arms on my 350 CI chevrolet engine. It has a hydraulic cam and I want to use either 1.5 or 1.6 ratio roller rocker arms. I also am replacing the heads with World Sportsman II heads. Also is there a way to get a ballpark idea what lift my current cam is short of removing it from the engine ? Thanks for the help
Joe
Old 08-27-2002, 05:30 PM
MI2600's Avatar
Member# 3287
Post
You can use a dial indicator on a push rod (you may use some four letter words getting it set up right!). Then multiply the movement by 1.5 if you're using stock rockers.
