Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - roller rocker dilema
Old 08-12-2012, 01:15 PM
Richiehd's Avatar
Richiehd Richiehd is offline
JS-70
Originally Posted by dave350v8 View Post
Basically the polycaps screwed onto the rocker studs ok for the first 3 or 4 turn then they started "cutting the threads up"
If the rockers became loose would I just loose the cam lift,similar to a pressed in stud pulling out.
Yes, but do they have allen screws to lock in place? Sounds like studs are worn from original rocker nuts.
