Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - roller rocker dilema
Old 08-13-2012, 03:42 PM
dave350v8 dave350v8 is offline
Originally Posted by thinwhiteduke View Post
Some wrong there, either an inch/mm mismatch or as mud.man says poor quality machining (china?). You should be able to hold a stud in one hand and a poly-lock in the other and screw it on SNUG and EASILY by hand until it bottoms out. And I can get parts from USA to AUS in I week too. I see your in the UK, you sure it's not BSF or something weird?
Duke
Hi,the rockers and studs came from the states,like a few guys say ive probably ended up with chinese s**t, you just dont know what you are buying these days! Here in the UK like in the States used to make high quality products,we had the engineering background but now we are all going cheap!
Its not a inch/metric mismatch as 13 of them fitted perfect, unless the batches got mixed up at the factory,thanks again to everyone with your opinions at least Im not the only one coming across these problems!
