Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Roller Rocker help
Old 04-04-2005, 07:38 PM
Docs91RS's Avatar
Docs91RS Docs91RS is offline
Originally Posted by johnsongrass1
Grind enough to clear. A search of the board will give you post's on this very subject.
Although it may work, I wouldn't recommend fly cutting the the crane energizers he's using to clear the longer valves retainer. They have a cast aluminum main body which might be dangerously weakened by the process.
Doc
