Roller rocker problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2009, 06:01 PM
Curtis
Last journal entry: dash of 68 camaro
I have a small block 400 with the stock crank with 6" rods. It has been bored 30 over and has been lined bored. It is a complete roller motor. I bolted a set of world heads on the block and begin to adjust the valves. The problem is the throat of the crane roller rockers hit the valve retaining ring before the valve gets adjusted. I called jegs and they said that I have the correct set of roller rockers ---- does anyone know what is wrong
Old 05-18-2009, 06:14 PM
Pushrods too short?
Old 05-18-2009, 06:18 PM
ericnova72's Avatar
More for Less Racer
Pushrod length may be incorrect, have you checked your rocker geometry?
Old 05-18-2009, 07:22 PM
Curtis
That is what I figured the problem was---- But I got confused when a well respected hot rodder friend stated that I had to have special rockers for a set of world heads--- and I never heard of that. Do I need to get a push rod length checker and check the geometry out.
I don't understand why the push rod length would be different than stock because the heads seem to be the same height as the stock ones
Old 05-18-2009, 07:34 PM
ericnova72's Avatar
More for Less Racer
Do these heads have .100" longer valves? What World head is it? Longer valves are common in aftermarket heads.
Old 05-18-2009, 07:57 PM
Curtis
world sportsman heads bought from jegs
Old 05-18-2009, 08:16 PM
ericnova72's Avatar
More for Less Racer
If these were purchased assembled for use with a solid lifter, hydraulic roller, or a solid roller then they will have +.100" longer valves to accommodate the larger, taller valve spring. Did they have a -1 or a -2 at the end of the part #? The -2 has longer than stock valves.
Old 05-18-2009, 08:59 PM
Curtis
it has a two at the end
Old 05-18-2009, 09:16 PM
ericnova72's Avatar
More for Less Racer
Time to check your goemetry so you can order the correct pushrods.
Old 05-19-2009, 12:35 PM
This is not unusual, often the rocker needs to be clearanced to miss the retainer. A high speed die grinder or Dremel tool with as fine a stone as you can get, relieve the offending area to provide a minimum of .050 inch clearance. Polish your work so as not to create any stress risers that can foster crack formation.
Be sure to get your push rod lengths correct for the proper sweep on the valve stem, directions are on the Comp site in technical help. check your clearances thru the entire sweep of the rocker for slot to stud, rocker to retainer, spring coil to coil, retainer to top of guide or seal, sweep on the stem, push rod to guide or clearance hole. If using a self guided rocker, guide edges to retainer. .050 inch is a good minimum for all of these.
Bogie
Old 05-19-2009, 12:44 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Good catch!
lifter cam rocker problem tomthecomic Engine 8 10-26-2008 09:38 AM
roller rocker arms wayneo Engine 6 02-29-2008 08:54 AM
roller rocker tips off center from side to side awoodman Engine 8 11-17-2007 08:25 AM
1.7 ratio roller rocker on a SBC 383vette Engine 1 10-15-2003 10:15 AM
Rocker or Roller Cam Fatt Matt05 General Rodding Tech 3 09-09-2003 09:46 AM
