roller rocker tips off center from side to side - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2007, 04:44 PM
How do I adjust where the tip of the roller rocker is in terms of left to right (not the whole pushrod length thing) Some of the tips should move to to right or left a bit so theyre not hanging off the edge of the stem causing uneven weight distribution on the tip. Do I just loosen the pushrod guideplates and move them either right or left? Thanks
Old 11-16-2007, 05:30 PM
King of my Man-cave.
Yep. Make sure that the sealer on the rocker studs is a non-hardening type or you will have to re-seal them. (Make sure that if the studs go through the intake ports that you remove any sealer crumbs that may fall out of the stud holes). The alignment doesn't have to be perfect, you just don't want more than 1/3 of the rocker contact point hanging off the valve tip.
tom
Old 11-16-2007, 06:31 PM
This is usually not adjusted for, it's one of those things with stud mounted rockers. However, you had a thought about adjusting the push rod guide plates and this is a bit on the right track. Isky sells a two piece guide plate, you can use this to offset each push rod to shove its rocker over a little. This will fix the condition if your existing guide plates are the cause of the offset. If the cause is the result of machining discrepancies where the stud and the guide aren't in the same line as the push rod, you can lean the rod a little, very little, to shove the rocker over. You have to watch for binding the push rod in the guide when doing this, which is the limit of your adjustment. Keep in ming that heavy springs will tend to bow or bend a leaning push rod so it this is a full up race engine expect failures of the push rod every so often. Doing this on a ball mounted pushrod can result in the rocker tipping at the valve stem which will wear funny if it doesn't break the rocker out right.
Bogie
Old 11-16-2007, 06:34 PM
ok, im going to go through every rocker and see what i can do about it, but how do I tighten the rocker nut? It's a nut with a setscrew inside of it. Do i finger tighten the nut until it stops due to the hydraulic lifter spring and then torque the hex screw in the top of it to a certain amount? how many ft. lbs??
Old 11-16-2007, 06:53 PM
charger528's Avatar
CHEVY,DODGE OR FORD
and for adjusting see post setting valve lash in engine section
Old 11-16-2007, 06:58 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
For a 3/8" stud it will take a proper sized allen wrench and a 9/16 box end wrench, Hold the hex nut steady and loosen the allen, it is a locking screw. Then you can adjust your rockers to the proper spec, when adjusted, again hold the hex nut steady and tighten the allen set screw.
Old 11-16-2007, 07:48 PM
Originally Posted by charger528
CHEVY,DODGE OR FORD
oh sorry its a small block chevy
Old 11-17-2007, 06:54 AM
what torque do I tighten the hex nut to, though? Thats what im wondering
Old 11-17-2007, 08:25 AM
1ownerT's Avatar
Wiki Edits: 4
There is no torque spec on small block chevy rocker arms. Do a search on here for valve lash adjustment. Once valves are adjusted properly, then lock down the adjuster.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Roller rocker alignment Chevy BB LeadfootBob Engine 1 06-04-2006 04:17 PM
top dead center & rocker arm adjustment Dreadlord Engine 1 09-27-2004 08:48 AM
Roller Rocker Arms brainsboy Engine 10 02-04-2004 12:32 PM
Need Roller rocker help Ebbsvette Engine 11 01-09-2004 03:10 AM
