Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Roller Rocker vs. Roller Tip Rocker
Old 01-05-2008, 11:12 AM
Siggy_Freud's Avatar
Siggy_Freud Siggy_Freud is offline
I guess the main point I want to get across is to not rule out full roller rockers for fear of maintenence.
If cost is an issue, there are ways to alter the block using a holding plate in the lifter valley so that you can run a stock roller cam setup in a block that would normally require retro lifters. A retro roller cam setup can be very expensive.
Bringing history and technology together.
