Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Roller Rocker vs. Roller Tip Rocker
Old 01-05-2008, 11:30 AM
Ozz1967's Avatar
Ozz1967 Ozz1967 is offline
Air Force Guy
Originally Posted by Siggy_Freud
I guess the main point I want to get across is to not rule out full roller rockers for fear of maintenence.
If cost is an issue, there are ways to alter the block using a holding plate in the lifter valley so that you can run a stock roller cam setup in a block that would normally require retro lifters. A retro roller cam setup can be very expensive.
I just looked through my summit catalog and got off the phone with their tech people and yeah, retro roller stuff is damn expensive.
If I go with the 305, I'm looking at a Lunati Voodoo cam (.437 in./.454 exh)
LUN-60100 at summit for reference.
In the 350, I'm looking at the Voodoo roller cam with a (.507/.515)
This one is LUN-60120 at summit.
I'll post the specs for the motor in a different thread when I get to it, so I guess in this thread I was looking for the pros-cons of the roller rockers vs. roller tips for my planned build and which one would be more reliable over the long haul.
