Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Roller Rocker vs. Roller Tip Rocker
Old 01-05-2008, 02:31 PM
Ozz1967's Avatar
Ozz1967 Ozz1967 is offline
Air Force Guy
Originally Posted by MIKE FROM SM
Roller tip rockers are a waist of money. If you have the geometry set up correctly, the rocker arm tip doesn't travel across the valve tip. All the friction is in the ball/cup area. I would just run a new set of stock stamped steel rockers if you run a small cam. If you really want roller rockers, I actually had good luck with the cheap aluminum ones on my daily driver with a large hydraulic flat tappet cam.
So I'm better off -- or perhaps just as well off, going with a cheaper summit brand roller than say, the magnum rollers from comp cams?
