roller rockers - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2013, 06:04 PM
roller rockers
vortec hea swap useing edelbrock 60979 heads flattapet cam . witch roller rocker arm would be a better choise to use? scorpion 1035bl or lunati 85340 both are narrow body and self align
Old 03-04-2013, 06:14 PM
Richiehd's Avatar
JS-70
I am a fan of Scorpions, made here in USA, nice quality, and Ill bet they are less money than the Lunatis. Get the Scorpion pushrods too, after you do the geometry
The Following User Says Thank You to Richiehd For This Useful Post:
lowhirod (03-05-2013)
Old 03-05-2013, 09:15 AM
The Crane Gold Race rockers are nice, but are $400 a set, same design as used on the ONLY OEM GM V8 engines to ever use rocker rocker tips and trunnions, the 1996 LT4 Vette engine.
10758-16 Crane Gold Roller Rocker, 1.6 Ratio, Self-Aligning $404http://www.summitracing.com/parts/crn-10758-16
1618-16 COMP Cams Ultra Pro Magnum Rocker Arms $334
COMP Cams Ultra Pro Magnum Rocker Arms 1618-16 - SummitRacing.com
SCP1002BL Scorpion Race Series Rocker Arms $222
Scorpion Race Series Rocker Arms SCP1002BL - SummitRacing.com
peace
Hog
The Following User Says Thank You to Hogg For This Useful Post:
Old 03-05-2013, 09:23 AM
Landshark928's Avatar
FrankenPorsche
I've used the scorpions the last few years. No complaints and well made. Decent price for USA made.
The Following User Says Thank You to Landshark928 For This Useful Post:
Old 03-05-2013, 10:15 PM
rockers
I went ahead and got the scorpion 1035bl self aling narrowed rockers 245.00 free shipping summit do I need the high rise valve covers?
Old 03-06-2013, 12:38 AM
If you've ever felt the crappy bearings in cheap roller rockers, and know that the high quality pieces use much better bearings, you'll be very impressed just by the feel of the Scorpions. These are quality pieces. It's a very, very good feeling.
Pat
Old 03-06-2013, 08:37 AM
Richiehd's Avatar
JS-70
Im thinking no, and Scorpion will probably tell you the same thing. But I would check when you put the covers on
any difference when adjusting roller rockers over stock rockers, using self aligning? redfish211 Engine 1 10-12-2011 04:12 PM
Oil Restrictors with Solid roller cam and roller rockers RippinRon Engine 8 05-16-2010 11:15 AM
Roller Rockers Question - Roller Pin Coming Out leejoy Engine 9 11-27-2008 01:52 AM
roller rockers or roller tip rockers Jared Engine 18 08-01-2007 02:18 PM
standard rockers vs. roller tip rockers andybird Engine 6 02-27-2003 01:18 PM
