In my opinion the stamp rockers, or even the steel roller rockers are a better choice. You would not notice the difference in performance. Also, over the years the aluminum ones have had problems from breaking and coming apart. Unless you want to keep checking their condition every few weeks, go with the steel
Hold on a minute. Aluminum rockers do not fall apart, etc... You can run a set for years with no problem, just don't buy garbage. I have run aluminum rockers for years and have never had them fail (not even the cheap ones, they are just noisey).
I have never seen a set of "stamped" steel roller rockers. Please tell me where you saw these. There are stamped steel "poller" tip rockers. In that case the only advantage they have over stock rockers is that they will have a more accurate ratio, they do not reduce friction, etc... Now there are chromoly and stainless steel roller rockers, these are nice pices but, they will cost you. I am currently running chromoly rockers, I didn;t buy them because I thought ther were stronger or would last longer. I liked the design and the fact that they are rebuildable. I don't like to see anyone being misled. You do not have to "check aluminum rockers" every few weeks. I ran the same set for sveral years and never even took the valve cover off (hyd cam). When I upgraded the engine, I sold the rockers which were still in good working order, and these were not top of the line rockers they were cheapies. |
Rocker Arm, Stud Mount, Roller Tip, Stamped Steel, 1.6 Ratio, Fits 3/8 in. Stud, Chevy, Small Block Not that I have anything to add other than the link, I'm only here to watch
Those are just roller tipped rockers. Thats not really comparible with the aluminum rollers.
Vince |
great opinions
Thanks thats exactly what I wanted........opinions from people that have used them. I'm guessing then those other aluminum rockers that I read about with the debris were Proform or something cheaper.
I didn't think about the piviot ball, just the tips. Thanks for pointing out that oversight! |
my bad sorry
Ive een wondering the same question, what about a set like these uesed or new http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT vs the http://store.summitracing.com/defaul...0&autoview=sku
I'm looking at these 4 a 400+ HP SBC 383 Stroker Mustangsaly |
Ive ran both types roller tip and full roller. I like comp cams roller tip rocker very strong. I read a rocker arm shootout in one of my old mags. Roller tip rockers gained several hp over stamped steel rockers. Then they installed full roller rockers an the same engine 0 hp gain. I don't know how true this is, but it was published in Super Chevy a couple years ago. I suppose if the engine made over 5 or 600 hp then you may see gains in hp with full roller. The engine in Sup Chevy was a little over 450 hp. Heres how comp cams describes the magnum steel rocker......Magnum Roller Rocker Arms are:
STRONG: Magnum Roller Rocker Arms are made from 8620 chromemoly steel. This makes them stronger than die cast aluminum or stamped steel rockers. This superior material, along with the Magnum’s super stiff design, assures maximum lift because this rocker arm will not flex. ACCURATE: You can’t get maximum horsepower from your engine if your rocker ratio is off. Other rockers have been checked and found that they were as much as .040'' short on lift. The Magnum Rockers are super accurate. They check dead on every time. POWERFUL: The Magnum Roller Rockers can make between 15 and 30 horsepower over other rockers! Why? The secret is that not only does the roller tip reduce friction, the Magnum Rockers incredibly stiff design and super accurate ratios yield more effective valve lift. DURABLE: The roller tip design reduces friction by not scrubbing the valve end or pushing the valve stem hard against the valve guide. This in conjunction with super strong design of the rocker makes for a simple, bulletproof, and cost effective combination. Last edited by 67 Deuce 4 Me; 12-01-2005 at 08:04 PM. |
I didn't want to mention names, but the Proform rockers are the "junk" ones I was talking about. I don't know if they have started making better ones or not. The last time I had a set in my hands was a couple years ago.
67 Duece, That is the point I was making about the stock rockers vs. the roller tip. It's the more accurate lift that gives them an advatage over the stockers. There is one common mis-conception the roller tip does not actually roll, there is no bearing in the tips. The tip slides just like standard rockers. The reason is there is so much force on the tips that there is less resistance for them to slide (while covered in oil) over the tip of the valve. There was a study where a high speed camera was used and it proved this point. I can't find that info on the web though. You have to take what you read in magazines with a grain of salt, they will tell whatever the manufacture tells them to. One of the advantages of full roller rockers is supposed to be less heat in the oil. Also when spring pressures and lifts start getting higher the roller fulcrum will have an advantage over a ball and socket (stock or roller tip). I am not saying everyone should go out and buy roller rockers and I probably wouldn't have even responded to this post, but the first reply was very mis-leading and were not based on facts. Royce |
rockers
Whats the application????
pick-up truck??? race car??? 300hp??? 800 hp???? Keith |
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| roller rockers or roller tip rockers | Jared | Engine | 18 | 08-01-2007 01:18 PM |
| Proform roller rockers! *** is wrong? | Sagacious | Engine | 21 | 11-23-2005 02:58 PM |
| Which Roller Rockers? | coldfire96 | Engine | 3 | 04-04-2004 06:38 PM |
| Roller Rockers | black66 | Engine | 5 | 10-23-2003 07:32 PM |
