Roller rockers on BBC - any modifications? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2008, 01:14 PM
I have a 402 that I am changing heads on, and thought maybe I would switch out the stock rockers while I'm at it. I'd like to do some full rollers -- my question is, is there anything special about the installation? Can I just bolt them right in like the stock rockers and go? Do I need special studs? etc...
I will be running a 396 375 HP cam (520 lift) solid lifter, heads are closed chamber 2.19/1.88 valves, ported.
Thanks
Old 04-21-2008, 02:03 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
You may have to clearance the two rocker arms that come close the the valve cover bolt bosses. Because the rockers will rub on the valve covers. Even with tall valve covers.
There are sets that come pre clearanced but you can do it your self pretty easily as long as you keep the aluminum or steel dust out of the bearings.
Nothing special about the studs you will need but you may need some longer ones. Depending on what is in there right now. Don't buy the pro comp roller rockers they are more trouble than they are worth.
Old 04-21-2008, 02:05 PM
Thanks, sounds pretty easy -- so other than that I can just bolt in, set lash and go? Can I use the same (used) rocker studs?
Thanks !
Old 04-21-2008, 02:14 PM
Double_v23's Avatar
Pretty much, you will want to use a pushrod length checker to make sure that your valvetrain geometry is still where it needs to be, but if everything looks good then you set the lash and warm up the engine then reset it and you are good.
Obviously you will need poly lock rocker nuts with that setup but a lot of companies will throw them into the box with the rocker arms.
roller rockers mendoza Hotrodding Basics 6 05-11-2006 01:34 AM
Roller Rockers On the street? killerformula Engine 37 06-05-2004 12:20 PM
Roller Lifter and Rockers Silver_Camaro Hotrodding Basics 6 10-07-2003 05:12 AM
Installing Comp Cam Roller Rockers on 5.0L Ford Motorsports GT-40 mikebmac Engine 2 07-23-2003 10:22 PM
Summit roller rockers warlock Engine 1 04-17-2003 03:04 PM
