Roller rockers on centerbolt heads? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2006, 07:42 AM
staleg's Avatar
Last journal entry: Hand brake
Will adapters for perimeter bolt valve covers together with perimeter valve covers on centerbolt heads clear the wide, ordinary type, roller rockers?
Old 10-24-2006, 09:23 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Nope. Not on the set I saw.
Old 10-24-2006, 10:01 AM
Known traffic menace
Nope, Not even close to being tall enough. By the way are those self centering rockers? Perry.
Old 10-24-2006, 11:02 AM
On the engines we build we use the Crower stainless rockers or shaft systems and there are no clearance issues with those valve covers.
Old 10-24-2006, 12:30 PM
Mustangsaly's Avatar
no clearance issues with what valve covers ? the stock center bolt v covers ? or no clearance issues with the perimeter adapter plates and perimeter v covers ? I been wondering. can you buy center bolt v covers tall enough to clear roller rockers ? or are the dividers in center bolt v covers what stop the use of center bolt v covers and roller rockers from working together ?
thanks
Mustangsaly
Old 10-24-2006, 02:50 PM
staleg's Avatar
I found the answer at Summit's. They write this about the adapters:
"This is an adapter that allows centerbolt heads to use perimeter bolt valve covers. Narrow body rocker arms are required to clear the adapter."
Old 10-24-2006, 03:38 PM
thanks
Mustangsaly
The Crower stainless rockers I mentioned have smaller bodies and we use tall valve covers with no problems as we have seen the adp. from GM leak as far as I know no one uses them.
Old 10-24-2006, 03:51 PM
thanks, so prob the adapter is more to run a set of the perimeter bolt v covers for the guy wanting a period correct look engine.
I just bought a set of proform chrome center bolt V covers, but there no taller than the original GM center bolt v covers. but there for a 350 tbi suburban with original valve train, so no problems.
Mustangsaly
Old 10-24-2006, 06:18 PM
Here's a link to a thread on Corvette Forum with some good pictures. He had to grind down the drip tabs and also had to grind the center bolt towers for clearance.
http://forums.corvetteforum.com/show...r+modification
Old 10-24-2006, 07:14 PM
Bumpstick's Avatar
Hammer and a torch
I under took this problem back in 03... I used a standard Proform roller rocker and by notching the cross braces of the perimeter adapters from GM it clears the rocker shafts no problem... I did use a set of short chrome GM valve covers with no baffles and had no clearance issues at all... The combination of the adapters and the valve covers made for a pretty trick look... Should have seen the looks when I pulled a valve cover...
Here is a pic of what I had back then but sorry no close ups of the modifications but hey it wasnt very hard and was done real easy with a die grinder and carbide bit... I just marked them with a black majic marker and took my time...
Hey its no big deal...
Vortec`s with roller rockers and adapters
Oh and BTW for those that are wondering on the intake its a Team G with reg bolt pattern... We modded the heads to work with the manifold as I was messing with Vortec heads long before even GM came out with an intake... Pretty simple just lay out the holes with the proper tall port intake gasket and on the end holes have the machinest clamp them to the table and drill a 3/4" hole and put a plug in it and then drill and tap the hole to the reg 3/8ths SAE... This takes up the problem of the thin metal in that area and with the Team G its ports were just the right height to match the Vortec`s ports...
Canfields and Roller rockers 85Sierra Engine 4 11-15-2005 06:28 PM
Inline roller rockers? sicksixseven Engine 1 09-28-2005 06:33 PM
1.5 vs 1.6 roller rockers? Streetmaster Engine 10 09-09-2005 10:27 PM
Roller Rockers On the street? killerformula Engine 37 06-05-2004 12:20 PM
misaligned roller rockers? TVR383 Engine 5 05-31-2004 06:17 PM
