Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - roller rockers for sbc 350
Old 12-06-2006, 12:24 AM
7chevelle1 7chevelle1 is offline
you will probably have to pull heads 0ff and take to machine shop , have studs pulled and top of stud shoulders cut , because roller rocker set lower,if you don"t you probably won"t be able to correct adjust valves. And all of this depends on what type of heads you have. I didn"t catch what kind of head is on your engine. you probably need the screw in studs with guide plate also
