roller rockers for sbc 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2006, 08:30 PM
70ChvyNova's Avatar
I have a 350 engine (bored .030) with a crane energizer cam .454/.454 272/272 hydraulic flat tappet, edelbrock intake (performer rpm) and Holley 670 street avenger carb. I have stock heads with stock rocker arms. If I want to put full roller rockers on, just what exactly will I have to do. Will I have to take my heads to the machine shop or is there anything else I can do.
Any input is greatly appreciated
Old 12-05-2006, 08:42 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Most of them are a bolt-on. Just put them on, adjust, and run.
Many people insist on using longer studs for the locking nuts, but it depends on many things. I've never had a problem using them on stock studs but it could be a coincidence that I had the right brand of lock nuts or something.
You may also need tall valve covers or a spacer, but many small blocks are just fine with stock covers. There again it probably depends on who's locking nuts you're using.
Centerbolt valve covers require a special narrow-body rocker.
Old 12-05-2006, 08:45 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
I would use comp cams magnum roller tip rocker arms. I think full roller would be over kill for your combo. IMHO
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
There shouldn't be a problem but if you decide to get them make sure you check for interference between the corner of the rocker and the head bolt/stud. I have head studs and had an issue with this.
Old 12-05-2006, 11:24 PM
you will probably have to pull heads 0ff and take to machine shop , have studs pulled and top of stud shoulders cut , because roller rocker set lower,if you don"t you probably won"t be able to correct adjust valves. And all of this depends on what type of heads you have. I didn"t catch what kind of head is on your engine. you probably need the screw in studs with guide plate also
Proform roller rockers! *** is wrong? Sagacious Engine 21 11-23-2005 02:58 PM
roller rockers w/hydraulic lifters njbloodline666 Engine 2 02-05-2005 06:41 AM
questions about swapping to magnum roller rockers smlblcks10 Engine 4 10-05-2004 01:27 PM
Installing Comp Cam Roller Rockers on 5.0L Ford Motorsports GT-40 mikebmac Engine 2 07-23-2003 10:22 PM
Summit roller rockers warlock Engine 1 04-17-2003 03:04 PM
