Are roller rockers supposed to be so loud? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-23-2012, 08:46 AM
I have not measured the pushrods, but they are new out the box. I did swap the both the pushrod and rocker together with another cylinder and the noise stayed with the original location. It did not move with the rocker, so I don't think it's the rockers anymore.
I have not checked for rocker to retainer clearance.
They are both set at zero now and are fairly quiet. They do get a little louder as they warm up.
  #17 (permalink)
Old 02-23-2012, 08:49 AM
If it were the lifters, wouldn't the noise be coming from down in the lifter valley? Not in the rocker area at the top of the head? And both pushrods appear to be turning.
  #18 (permalink)
Old 02-23-2012, 10:22 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
Originally Posted by F-BIRD'88
You are not the only one that has found comp cams roller rockers noisey.
Assuming the cam is not loosing a lobe or the hyd lifter is not defective,
I use and recomend Scorpion roller rockers.
he didnt say they are comp brand
are they hitting the spring on the bottom of the rocker
  #19 (permalink)
Old 02-23-2012, 10:33 AM
I'll have to check on that when I get home tonight. It never crossed my mind, but you are the second one to ask that.
Thank you.
  #20 (permalink)
Old 02-24-2012, 02:32 AM
Nope, the noise would be coming out of the rocker assembly area, due to the play would actually be enhanced in the rocker assembly. Did you also check for the wear/contact mark on the valve tips too?
any difference when adjusting roller rockers over stock rockers, using self aligning? redfish211 Engine 1 10-12-2011 04:12 PM
Oil Restrictors with Solid roller cam and roller rockers RippinRon Engine 8 05-16-2010 11:15 AM
Roller Rockers Question - Roller Pin Coming Out leejoy Engine 9 11-27-2008 01:52 AM
roller rockers and cam VS. standard cam and rockers slipfreak84 Engine 5 09-30-2008 11:55 PM
standard rockers vs. roller tip rockers andybird Engine 6 02-27-2003 01:18 PM
