Roller rockers under stock valve covers - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2006, 04:20 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I have stock centerbolt SBC valve covers and want to put roller rockers under them. I can't use taller covers because its in a boat and there is no room between the valve covers and exhaust risers.
How do I get full rollers to fit under there? Is it the rollers themselves, or the polylocks that are the problem?
Old 11-19-2006, 06:37 PM
Jmark's Avatar
About all you can use under stock covers is roller TIPED rockers and not full roller. The lock nuts will hit the covers big time.
Old 11-19-2006, 07:25 PM
curtis73's Avatar
Wiki Edits: 16
Do you think 1/4" taller cover will clear it? I can run thicker carbon exhaust gaskets to throw the exhaust out another 1/16" which might give me enough room for 1/4" taller covers.
Old 11-19-2006, 07:39 PM
I have used the GM Performance 1.5 rollers rockers under a Centerbolt stock valve cover. The camshaft was less than .450 lift with 1.5 rockers.
Old 11-19-2006, 07:53 PM
We use all Crower stainless shaft rockers and there stainless rockers as I believe they will fit under the covers with no problems and check on the GM roller rockers used on the crate engines as they use stock covers.
Hope this helps
Roller rockers redneckbauer Engine 2 09-21-2006 03:02 PM
Short valve covers too tall... ChevApache59 Engine 11 12-06-2005 08:05 PM
Were to find-2 piece valve covers ALASKAN Engine 10 04-23-2004 11:40 AM
roller rocker and valve cover clearance 56madmook Engine 5 03-24-2003 03:53 AM
Stock eliminator 78 monte Engine 5 01-02-2003 06:10 AM
