roller stuff dont know what im doing - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2012, 05:52 PM
koltonmoe's Avatar
moe
Last journal entry: 1972 blazer
please help me i am 17 and i am rebuilding the motor in my 72 chevy blazer. its a 350 small block and i put a roller cam in it and roller lifters and roller rocker arms but i can not figure out how to find the right size pushrod length because iv bought 2 sets and one was to big and the other was to small...please help and my name is moe
Old 04-17-2012, 06:18 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Post the cam P/N and the rockers P/N so we can see exactly what you are working with.
Get one of these.
https://www.google.com/#hl=en&sclien...w=1264&bih=653
Cole
Amx 20277
You need to get an adjustable push rod to check for what length you need.
Old 04-17-2012, 06:40 PM
koltonmoe's Avatar
moe
well stock length is like 7.8in and they were to big so i then bought some 6.2in and they were to small so i did some math and i think i need 6.937in long
Old 04-17-2012, 09:14 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Is the block a late model roller block?
If not did you do the retrofit roller application?
You can not take a flat tappet block and throw a roller cam and lifters in it without additional work.
Old 04-17-2012, 09:17 PM
eloc431962's Avatar
Wiki Edits: 37
How did you come with the measurements?
Cole
Old 04-18-2012, 07:49 AM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
Why in the hell do engine post keep getting moved?
Old 04-18-2012, 11:50 AM
First question has to do with process. Here's a link to Comp Cams and the instruction for determining push rod length. Are you following this method?
http://www.compcams.com/Pages/417/va...-geometry.aspx
You'll see they recommend an adjustable push rod length checker, as has also been recommended in the responses to you. The pain of this is that push rod checkers aren't all that strong so you need a light weight spring which drives you into an assembly and disassembly of the head to set this up, check, then tear the set up down to replace it with the intended service spring. This can be done with the head on by bringing the piston almost to TDC then filling the combustion space with rope to support the valve to have the springs replaced then using a tool make for this purpose to compress the spring to be removed and its replacement for service installed. Don't forget to take the rope out of the chamber when you're done.
As you're seeing, getting a hot rod engine built is not all that easy. As you move away from the factory design you spend a lot of time having to mock the engine up to check dimensions then tear it down to put it back together again. Once you get the push rod lengths correct you'll need to go back and check for piston to valve clearance which is likely to involve another top end assembly-disassembly-reassembly routine. An aftermarket roller cam is very likely to have piston to valve clearance issues because of the higher lifts and longer durations involved. You have to go at it carefully you can't assume that everything just fits together.
Bogie
retro hit hyd roller cam in oe roller block? 973kgt Engine 4 07-26-2010 09:54 AM
Oil Restrictors with Solid roller cam and roller rockers RippinRon Engine 8 05-16-2010 11:15 AM
Hyd. Roller lifters on Solid roller cam danrace1 Engine 6 01-28-2010 06:21 PM
SBC Factory roller lifter retro on non roller block 383ram Engine 1 01-24-2009 08:16 PM
Cam lube gray-graphite stuff vs. the red stuff. 78 monte Engine 28 01-23-2003 11:24 PM
