roller tip rockers - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2007, 09:30 AM
Bill Yarbrough's Avatar
roller tip rockers
Can I expect any noticable change if I use roller tip rockers on a stock 88 Corvette Tuned Port engine? How about 1.6 rockers? The car is driven daily and weighs 3700lb.
Old 07-11-2007, 09:55 AM
302 Z28's Avatar
Comp Cams states a HP gain, but my experience is you will never feel it. I installed a set of Comp Cams roller tipped rockers on my Fastburn and really didn't notice any difference. Having said that, I feel they are worth the expense as it reduces a wear point and makes the valve train a little more durable. I obtained mine from an Ebay store and saved quite a bit over what Jegs or Summit wanted and they were new in a sealed box from an authorized dealer.
Vince
Old 07-11-2007, 10:20 AM
Last journal entry: PICTURE TEST
rockers
On a street driven car looking for a seat of the pants feel,more then likely nothing will change.
If you do decide to buy them get the Comp Cams...I have had some of the off name roller tips in my shop and the roller is big and not in the correct location and it will mess up your push rod geometry.. The comp cams rockers are spot on.
Keith
Old 07-11-2007, 10:44 AM
Irelands child's Avatar
I have the 1.7 Crane's in my Ford 5.0 rather then the OEM 1.6's. I installed them for a couple of reasons - I went to a "bigger" cam and wanted all it would give me. Secondly, the Ford OEM rockers tend to cause side thrust wear in the valve system - guides and valves. And then, lastly, braggin' rights.
Will I feel the difference?? Most likely only in my mind where it counts most. It's a pretty tame engine otherwise
Dave
Irelands child
Old 07-11-2007, 10:52 AM
Bill Valentine's Avatar
rockers
Dave,
When I raced 351 Cleveland motors, a neat trick was using a combination of 1.7 &1.6 rockers.
Old 07-11-2007, 11:20 AM
Originally Posted by Bill Valentine
Dave,
Bill,
Which rocker went on which valve? Clevelands are a different "beast" then my little 5.0 though might have considered it on the BIG 351W I ran a few years ago
Dave
Irelands child
Old 07-11-2007, 11:23 AM
rockers
1.6s were on the intakes
roller rockers or roller tip rockers Jared Engine 18 08-01-2007 01:18 PM
Roller tip rockers Kmart Engine 20 01-29-2006 11:03 AM
roller tip rockers Turbo Terror Engine 1 02-16-2005 02:03 PM
standard rockers vs. roller tip rockers andybird Engine 6 02-27-2003 12:18 PM
Adjusting valves with Roller tip rockers...... joakes Engine 6 10-19-2002 05:54 PM
