Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - roller tip to valve tip alighnment
Old 07-29-2007, 07:36 PM
ernkazern ernkazern is offline
Roller tip
They should be right in the center. You can use magic marker or prussian blue to test for this. You mark the top of the valve then turn the engine over and look for the clean spot. You change the pushrod length to change the contact point on the valve stem.
