Rolling Fender Lips - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2004, 05:48 PM
Last journal entry: Rambler update
Rolling Fender Lips
Got a quick question, and need a quick answer...I need to get a little bit of clearance out of my rear wheel wells on the fender side. The lip that points back in rubs my tires a little when I hit a bump...should I just grind them down, or is there a more appropriate way? thanks
Old 07-01-2004, 06:23 PM
BOBCRMAN@aol.com's Avatar
You can carefully roll the lip up on the inside. Hammer and Dolly. Most Nova,Camaro,Chevelles from the early seventies, that were drag raced, have had this done.
Old 07-01-2004, 08:57 PM
sportbikeluvr's Avatar
OR if you have the dough > check this tool out!
Old 07-01-2004, 09:08 PM
Mirror Image's Avatar
I would also hammer and dolly you don't need to grind the lip off because this is where the outer quarter is welded to the inter quarter
Old 07-02-2004, 01:32 AM
dinger's Avatar
I'm not reccomending this, a two by four between the wheel well and the tire. I have seen it done, it flared enough to keep the tires from rubbing.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 07-03-2004, 11:34 PM
rolling fender lips
A baseball bat works better than a 2x4. Works pretty much like that fancy Eastwood tool.
Wally
