We're winning the case!
Hotrodders Bulletin Board > Tech Help > Interior
  #1
Old 01-02-2003, 10:12 AM
rdk409 rdk409 is offline
New Member
Question rolling the top of custom door panels
I am in the process of building a 81 Camaro and want to do my own custom door panels. The question that I have is how to roll the top of the panel over the top of my door so that it will fit like the OEM panel? Is there a meterial that I can form with a heat gun to match that of the OEM and will stay once it cools back down?
I hope everyone understands what I am asking.
THX
Old 01-02-2003, 10:15 AM
meanmachine666 meanmachine666 is offline
Post
you can use either ABS plastic or fiber board fiber board is a steam heat bend and ABS can be bent using a heat gun set on low to med.
Old 01-02-2003, 11:01 AM
New Member
Cool
thx...Will I have to do something to either material to keep it from "un-forming"? Or once it is heated, bent, and cooled it will stay that way unless heated back up with a heat gun/steam? I guess what I am asking is will the sun make it "un-form"?
thx
Old 01-02-2003, 08:54 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Post
in the old days we used to use sheet metal, form it over a pipe, brake a mounting edge on it trim to fit fiber panel then rivet the two together and cover, also gives you a place to mount the inner glass wiper,on the panel edge.
Old 01-03-2003, 06:30 AM
New Member
Post
THX for the reply's. Bob, I just have a qestion. If using sheet metal, why would you need the fiber board? For additonal strength so that the sheet metal will not flex? Or so that you can glue the material to it easier than you can the sheet metal? I am kind of lost here, sorry but I am very new to the custom interior thing...
THX again for everyone reply's...
Old 01-03-2003, 09:28 PM
Post
its much easier to work the fiber board, you can use factory type fasteners on it, its easier to glue and staple to, easier to trim for accessorie holes etc.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
