Romoval of old sound deadener could use some advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2009, 01:04 PM
I am gutting a 65 Thunderbird to clean up the passenger compartment.
It seems it was a home for a few rodents, and has a bad mildew smell. I am likely going to use a mild bleach to clean and disenfect the pasenger cab.
I am also trying to remove the old factory sound deadener out of the cabin as well, having problems leaving tons of sticky tar like substance.
I was wondering if ther was an easier way or a few tips on removal of this crud.
Thanks for taking a look.
Old 01-25-2009, 02:21 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Here's a thread with some ideas for you. Mikey's right, if it's hard enough, the needle scaler works great. CLICK HERE Good luck.
Old 01-25-2009, 04:16 PM
wildthing's Avatar
Last journal entry: 95 % done
in my wheel wells i used one of those small propane torchs , that you use for plumbing. heat it up a bit then scrap it off with a putty knife. i finish it off with one of thoses nylon pads from lowes ,,looks like a pot scrubber on a 4 1/2 grinder.
Old 01-25-2009, 06:41 PM
Steam!
Go to your local hardware store. Pick up a wallpaper steamer. Steam will loosen it up in a safe way.
Steve
Old 02-07-2009, 11:25 AM
the best thing i have found is freezing it with dry ice, then use a flat head scew driver and hammer/mallet. It leaves it super clean and you don;t have to worry about harmful chemicals and solvents.
Old 02-07-2009, 11:50 AM
How about the removal of a 4-5 month sound deadner mat?
Its ashphalt based I beleive, and seems fresh still.
Old 02-07-2009, 11:51 AM
Actually its Butyl Mat
Old 02-07-2009, 01:25 PM
Wiki Edits: 22
The dry ice is a great idea. If solid enough, the air powered needle scaler will make quick work of it, and is much simpler.
Old 02-07-2009, 06:22 PM
Dry Icing it sounds like it could take damn near forever, is it actually pretty quick?
Old 02-08-2009, 07:37 AM
Wiki Edits: 22
Dry ice is solid carbon dioxide, and its temperature is -109 degrees F, way colder than regular ice. It also returns to gas form and not liquid form when it "melts". It would work quick and not leave anything behind.
Old 02-15-2009, 03:18 PM
Dude it is so fast,you could do it in an hour, rather than an whole day
Old 04-04-2009, 09:14 PM
no luck on the dry ice, 2 big blocks later and the stuff was still a pain in the *** to remove.
Lots of cursing and 3M adhesive remover seems to work well. However the Adhesive remove somewhat just kind of melted it so its pretty nasty goo now... Im gonna need some more shop towels...lol
Old 04-04-2009, 09:45 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Which reminds me, the fumes are bad for you.
newbie advice davemad Introduce Yourself 1 01-15-2009 10:16 PM
Guess that sound, video inside. 5_speed Engine 12 12-28-2008 05:53 PM
exhaust advice ppd668 Engine 11 09-28-2007 11:53 PM
Annoying Vibrating Sound 66chevy2ss Engine 12 07-07-2003 05:32 PM
Sound Deadener Stinkin_V8 Interior 22 12-12-2002 07:02 PM
