Hotrodders Bulletin Board > Tech Help> Engine
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 09-11-2002, 07:11 PM
johnsongrass1's Avatar
johnsongrass1 johnsongrass1 is offline
Race it, Don't rice it!
Post romp'in in style
Anyone ever run edelbrocks RPM cam? If so then did anyone have problems with this bumpstick on the street, Edelbrock promised me it was 100% streetable but I'm beginning to have serious doubts. Symptoms include surging that can't be taken out from the carb tuning or dist. timming. Without running so little timming power really begins to fall off.
  #2
Old 09-11-2002, 07:54 PM
Quepas00's Avatar
Quepas00 Quepas00 is offline
Post
Normaly you have surging because your retarted. (No pun intended) Advancing should smooth it out. The 1st thing I would look for is a vacuum leak.
Old 09-12-2002, 08:20 AM
bullheimer's Avatar
bullheimer bullheimer is offline
BP-screw you!
Last classified ad: 1955 1956 1957 Chevy 4x4...
Post
I agree with the cute little grip. squit starter fluid around your intake manifold if it picks up r's its suckin it in. i had this happen before way back in the 1900's so i cant remember what it was. seems like float adj was off or some kind of carb problem. i do know it's a common problem i've seen alot of but cant for the life of me remember how to fix it.GEE I HOPE THAT HELPS!! <img src="graemlins/drunk.gif" border="0" alt="[drunk]" />
Old 09-12-2002, 09:02 AM
MHenricks MHenricks is offline
Post
I wouldn't use starter fluid, use wd40 it works good, starter fluid could do damage if you use too much.
Old 09-12-2002, 10:53 AM
4 Jaw Chuck's Avatar
4 Jaw Chuck 4 Jaw Chuck is offline
Post
Propane works the best.
Outlawed tunes from outlawed pipes
Old 09-12-2002, 11:42 AM
Madd Syntst's Avatar
Madd Syntst Madd Syntst is offline
American Madd Man
Post
I currently run one in a 72 BB OLds and I have had NO problems so far!
(Knock on wood)
Old 09-12-2002, 12:33 PM
Quepas00's Avatar
Post
Unless you want real short curly hair I would be very carefull using propane around a running engine.
Old 09-12-2002, 03:31 PM
Post
It's Garenteed not to have vacuum leaks. Your olds is a big block allowing it tolerate more cam. I'm running a 355 with this cam. runs really well except for the darn surging at cruise speeds,at say, a few degrees of throttle opening. I can't even garentee the carb is even out the idle circiuts! Case anyone needs to know cam pulles 10' vacuum at idle and 14-16 at 1500 RPM.
Old 09-13-2002, 02:34 AM
KULTULZ KULTULZ is offline
aka Duke of URL
Thumbs up
[quote]Originally posted by 4 Jaw Chuck:
Propane works the best.<hr></blockquote>
[quote]Origionally posted by Quepas00:
Unless you want real short curly hair I would be very carefull using propane around a running engine. <hr></blockquote>
Propane is the proper and safest method of determining a vacuum leak or lean run condition.
It requires a wand with a flow regulator. You put the wand tip to the carb/throttle body opening and slowly open the valve. Once idle has stabilized, you pass the wand over all suspect air inlet gaskets until the idle stabilizes again. You found your leak.
The trick is to keep the propane bottle upright as if you tip it, liquid propane could be released subjecting you to fire and/or explosion.
What I fear most is someone shooting either or carb. cleaner onto a hot running engine. Same with WD 40 as it has kerosene in the mixture. The above also make a mess on the engine and stain painted/polished parts.
PS; Also make sure you know where the shop fire extinguisher is located before attempting any of the above...
Old 09-13-2002, 05:57 AM
BstMech's Avatar
BstMech BstMech is offline
NYOFP4RJ3CHRIS
Post
Just curious, What about the torch? Would acetlyne work?
Old 09-13-2002, 10:13 AM
Quepas00's Avatar
Post
Propane in any form, gas or liquid is extremely flammable and easily ignited by a spark. I can just see some kid dragging the ol BBQ propane bottle into the garage, hooking a hose up to it and cranking open the valve while looking for a vacuum leak around his manifold. O my gosh! theres the distributor...KA BOOM!!!
Old 09-13-2002, 12:43 PM
aka Duke of URL
Question
Then do you find it odd that carburetors are calibrated to an emission engine application with propane?
I said wand. There is a special service tool available that is a reinforced hose with a twelve inch aluminum wand attached that has a regulator to control flow.
If you think propane is explosive, what about ether or carburetor cleaner?
How about a little help here 4-Jaw?
Old 09-13-2002, 01:55 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Last wiki edit: How to Rebuild a Rochester Quadrajet 4MV Carbureto...
Last journal entry: Final Fisher Body car restored
Wiki Edits: 21
Post
4-jaw. I have been trying all afternoon to fill a Coors can with propane. How do you get it to saty in there? Maybe you use Molsen Gold cans instead?
Old 09-13-2002, 02:20 PM
Quepas00's Avatar
Post
I understand what your saying, But 4 JAW did,nt make it to clear on how to use propane. Some one could hurt themselves and others. If you have a regulated wand with the shut off button on the handle thats fine but I don't think to many back yard mechanics have such a tool. Next time your in a smog check station ask the guy, when was the last time he used his propane bottle in a test.If and when they do use it in a test its introduced to the engine thru a vacuum source. (I think)
Ether and carb cleaner are more dangerous. Spray some around your EGR valve when its by-passing and you may have a good size fire on your hands.
Anyhow I did'nt want anyone to burn down thier garage.
[ September 13, 2002: Message edited by: Quepas00 ]
[ September 13, 2002: Message edited by: Quepas00 ]</p>
Old 09-13-2002, 03:17 PM
aka Duke of URL
Thumbs up
...understood...
Guess I had better watch what I say and how. I accept too much I guess...
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
