ron francis wiring problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2007, 03:27 PM
ScottRods2945's Avatar
I have a ron francis advantage plus wiring harness in a 66 el camino with dakota digital gauges, power windows, and door poppers. My problem is that when I plug the battery cable up I hear a clicking sound coming from the fuse box is this normal for the ron francis wiring harness or is this something I done wrong. I tried to follow all of the directions to a tee so if anyone has any idea of what I may have done wrong let me know and i will check it out.
Thanks
Old 08-03-2007, 07:37 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I have the horn relay inside my car mounted to the fuse box.
could not figure out why the battery kept going down. (horns not yet installed)
Turns out--a bad part in the steering wheel install kit was grounding the horn circuit, thus turning on the horn relay.
Could also check the remote box for your door poppers----could be a relay that deactivates when the car is running-(wish my remote had that feature--too lazy to wire one in now)
Could be a two people job---one under the dash---one connecting the battery.
Gotta love those DD gages--Power windows--door poppers
I have all this stuff on the 59 Elky in my avatar. 454/TKO 5-spd
One of my 66 elkies will get the same thing----'cept with a small block
The OTHER 66 Elky is a factory 396/4spd/tilt/kneeknocker tach/buckets---Not gonna mess with this one too much.
Bryan
Old 08-03-2007, 08:36 PM
T-Bucket, Corvette, Mustang
Turn signal flasher relay running?
Old 08-03-2007, 08:44 PM
Bryan59EC's Avatar
good one---
4-ways were an option in the 66 Chevelles.
Perhaps if you have them---they are on.
Or an aftermarket tilt wheel or later oem tilt----hazards could be on
(Ididit tilt in the 59)
Bryan
Old 08-03-2007, 10:48 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Check to see if you have lamps flashing when you hear the clicking..if you do, you probably have a switch incorrectly wired on the flash (or 4 way if used) that needs checking..
IF you don't have lamps flashing, pull the flashers see if the noise stops..if so, you have another device pulling current from the flasher system (s) you need to isolate and remove..
To do that, simply turn EVERYTHING on and look for whatever goes on/off with the "click"and make it right.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 01-02-2009, 09:35 AM
Ron Francis wiring problem
Thanks
Might I suggest you pull the flashers one at a time to see if the sound goes away. Also, if it is an electonic flasher, it may be flashing even though the lights don't. Otherwise, please call ron francis tech department at 800.292.1940 or email ron at ron@ronfrancis.com
Old 01-02-2009, 10:08 AM
malc's Avatar
Born To Be Mild
It was a long time ago, 08-03-2007, he must have figured it out by now.
Old 01-02-2009, 10:29 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
I sure hope so....
Old 01-02-2009, 01:52 PM
Last journal entry: Bringing home the 401 Nailhead
Brings up a point that I am guilty of sometimes. Wish the OP would post back with the findings/solution so that others may benifit.
Possible wiring problem Phxamigo Electrical 6 02-06-2007 03:15 PM
Engine stalling problem JamesRS Engine 3 01-30-2006 11:22 AM
Ignition Problem malibuman66 Electrical 17 01-24-2006 01:05 AM
Altnator Wiring Problem 1954 Ford Neal0o Electrical 1 09-04-2004 10:14 PM
Fuel / Carb problem DoubleVision Engine 5 10-28-2002 05:18 PM
