Roof - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-16-2006, 03:55 PM
car builder
I would just cut A roof skin off of A donor car and then
trim yours off as close to the rails as possible.(leave about 1 inch all the way
around).
Then lay the donor up on top and tack it in place.
when welding make certain that you do not warp it.
Grind the weld and use A thin coat of bondo for contour.
How critical is the roof skin on a unibody car? beemdubya Body - Exterior 19 08-04-2006 09:26 AM
metalshaping and panel replacement '40 Willys roof Randy Ferguson Body - Exterior 18 11-26-2005 10:00 PM
roof flexing CaPrI_MaN Body - Exterior 5 07-29-2005 07:54 AM
Help with 53 chev 2 dr sedan roof chop FroFro Body - Exterior 2 05-04-2004 09:29 AM
the roof! the roof! the roof is on fire! DragLinkscc Hotrodders' Lounge 18 09-20-2002 09:22 AM
