Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 07-28-2005, 10:07 AM
CaPrI_MaN's Avatar
CaPrI_MaN CaPrI_MaN is offline
roof flexing
Hi there!
Today I finished striping the roof of my capri to bare metal. A long time ago I noticed that some zones of the roof flex, will this lead to paint cracks in the future? After striping all the paint I noticed that the roof is completely dentless not even a little dent!!!!! Without the pain I can see that the roof as never been repaired, what could cause that flex in some zones of the roof?
António Costa
from Portugal
Old 07-28-2005, 03:43 PM
rrmccabe's Avatar
rrmccabe rrmccabe is offline
GM Muscle
re: roof flexing
Do you mean that you can push down the roof and when you let release it pops back up? If so, this is normal on many cars. Panels are just not supported that well.
Be careful when you block sand the fill primer and you let the sandpaper do the cutting and do not press down to sand the primer or you will be blocking it in the dented position.
Now if the panel is so flimsy that it pops in and out pretty much on its own then you might need to do some shrinking on the panel to firm it up. But based on what you are saying I think you are OK.
Old 07-28-2005, 04:11 PM
CaPrI_MaN's Avatar
re: roof flexing
It's that way it happens. Its good to know that its normal to happen. Thank you for the help. I was a little worried about it... but if you say that its normal. There is no reason to be worried.
António Costa
from Portugal
Old 07-28-2005, 05:33 PM
rrmccabe's Avatar
GM Muscle
re: roof flexing
Some cars are better than others. Its not unusual to find some with very flat sections that will pop in and out.
Rich
Old 07-28-2005, 06:50 PM
BondoKing's Avatar
BondoKing BondoKing is offline
KING OF BONDO
Oil canning
CM what you are referring to is called oil canning.. it happens when the metal has stretched in that area and is secured in all corners.. Really it is best to shrink the metal. There are several different methods to doing this, torches, shrinking disk, shrinking hammers, etc.... It may be a task you wish to embark on and it may be one you wish to leave alone and work around.. It is up to you..
Matthew
Old 07-29-2005, 05:54 AM
CaPrI_MaN's Avatar
re: roof flexing
BondoKing, I think that it would be a mistake to shrink the metal, for what I've noticed today the problem is that the panel is not well supported,like rrmccabe said. I don't think that shrinking the metal woul solve the problem. I remember that when the VW golf IV was released (1998) a friend of mine bought one and when he was washing it he noticed the same thing happening to the roof, so when he started to try to press with his hand the roof on others Vw Golfs that he saw parked on the street he noticed that all add the same problem, the roof is badly supported on that cars as it is on my 74' Capri.
So I must agree with rrmccabe about the panel beeeing badly supported.
Thank you all for your help and sorry for my bad english.
António Costa
from Portugal
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "roof flexing"
metalshaping and panel replacement '40 Willys roof Randy Ferguson Body - Exterior 18 11-26-2005 08:00 PM
filling the roof 35 buick40 Body - Exterior 8 04-07-2005 10:35 AM
Question about removing roof 86caprirs Body - Exterior 3 03-27-2005 11:21 AM
Help with 53 chev 2 dr sedan roof chop FroFro Body - Exterior 2 05-04-2004 07:29 AM
the roof! the roof! the roof is on fire! DragLinkscc Hotrodders' Lounge 18 09-20-2002 07:22 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
