Roof insulation affect headliner bows? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2010, 12:06 PM
Last journal entry: Body work
Before I install the new headliner in my 59 rambler I want to insulate tho roof.
The insulation is about 3/8 to 1/2 thick, foil on both sides with fabric center.
Will the extra thickness give me problems with the headliner bows and possibly cause the headliner to not fit correctly?
Thanks
Old 04-15-2010, 03:52 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
If the bows touch the insulation, just V cut the foil under the bows. Should be good to go.
Old 04-16-2010, 07:34 AM
DanTwoLakes's Avatar
Wiki Edits: 22
The insulation won't matter, even if the bows push up into it, the headliner hangs from the bows in listings that hang down below the bows. A lot of times, the insulation helps hold the bows in place while you do the headliner.
Old 04-18-2010, 08:09 AM
That makes sense thanks for the help.
Headliner Tutorial DanTwoLakes Interior 20 07-18-2011 07:45 AM
headliner bows, '57 chevy BA ht Joe D'Auria Interior 8 02-20-2009 11:45 AM
1964 Impala SS Interior Roof Insulation 64Joker Interior 3 07-30-2008 10:28 AM
Roof Bows 35WINDOW Interior 3 01-05-2007 10:33 PM
Headliner, etc insulation Wmarden Interior 2 12-04-2002 07:23 PM
