roof skin is off!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2010, 06:17 PM
roof skin is off!!
thanks brain for the advice.. im sure we will cut the new drip rail off so we can carefully get to the drip rail welds..also gonna put somthing on the structure to prevent rust..just not sure what yet..
Old 06-05-2010, 06:35 PM
merlinsoars's Avatar
Sin Vertis Stratio
Good job.... love the progress shots
As for the rust ive started using pour 15 on some parts and so far so good. May be some issues in and around where your going to weld.
Old 06-05-2010, 08:05 PM
Old Fool's Avatar
mechanically remove the rust and paint with SPI EPOXY if you want it done right
Old 06-05-2010, 10:26 PM
i wire wheeled the rust.. alot of it was just dust and "powder" rust.. not sure if i want to use por..mabey some other stuff... should use the spi epoxy but mabey ill just use some other treatment stuff i mite have laying around
Old 06-06-2010, 12:09 AM
I was going to say, don't sweat it too much, just a quick prime or somthing, it isn't a big deal. EVERY car has it in this hidden areas. It may be called "rust" but it is more of a simple "oxidation" of bare metal. Being it won't ever get wet and your car isn't going to be full of wet carpet or something, it won't get worse even if you left it there.
I am not saying to leave it, but any primer to protect it will be more than enough. But you do want some good protection where the pinch welds will be.
Old 06-06-2010, 12:39 AM
i will use seam sealer in the drip rails like the factory did.. im still picking away at that stuff... hope to start skinning the new roof 2marrow. theres alot of spot welds 50+ just in that drip rail. gonna take awhile to get it all welded up.
Old 06-06-2010, 01:40 AM
GMCTRUCKS's Avatar
Rust off.
I had seen once on some TV show that after they sanded down a section of the car to bare metal they would spray something on it so you wouldn't rust right away meaning this spray would keep the little rust off of it from forming over night. I can't remember the name maybe somebody here knows.
Old 06-11-2010, 01:51 AM
i ended up just puting some brushable rust converter on the frame after i knocked off all the dust/rust.
new skin is off! put aircraft stripper on the drip rail and window frames to get rid of the black goo and soften of the seam sealer. alot of dinking around to get all the seam sealer out.. my friend got the skin off in one peice..so far so good
its just sitting on the car for now. the back fits great but the front is a little high. i think its just cause the metal is not in the drip rail yet.. one we put a few screws in it to hold it down i think it should be ok
Old 06-11-2010, 08:21 AM
Wow...thats a lotta spot welds to drill. Makes me cringe looking at it. I am currently seperating a full quarter panel from the donor car (69 GTO) and this makes it look "easy".
Good job!
Roof Cutting/Grafting Options sparkydog Body - Exterior 7 12-28-2009 08:54 AM
Took sun roof out of 84 Cutlass cross members missing will roof rattle at high speed? heathj1 Body - Exterior 9 04-16-2009 07:28 AM
replacing a roof skin on a 69 dodge dart glhx Body - Exterior 49 09-01-2008 03:37 AM
Door skin installment sevt_chevelle Body - Exterior 17 01-20-2007 06:35 PM
How critical is the roof skin on a unibody car? beemdubya Body - Exterior 19 08-04-2006 08:26 AM
