roofs - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2013, 10:55 AM
model-a's Avatar
Last journal entry: tools
roofs
I would like to see some pictures of model-a sedans and the different ways ya'll have done tops,metal,fadric, or whatever.Thanks
Old 03-18-2013, 06:10 PM
I have a 28 model "A" 2 door sedan. I welded 3/4 square tubing with 12" spacing across the roof leaving aprox 1/4" clearance to the top of the side roof panel then installed 1/4" plywood cut to size then I used bondo to fill in the transition. It looks pretty good, initially I was going to use sheet metal but to weld it to the old body I was afraid lots of distortion and that's hard to repair.
Old 03-18-2013, 06:26 PM
model-a's Avatar
Got any pictures my friend
Old 03-18-2013, 06:38 PM
Roofs
Don't have any at this time but I'll see if I can get some
Old 03-19-2013, 10:21 AM
I used a two part body adhesive. Very expensive but works amazingly. I then tact in the top very carefully so that nothing warped. Then I glassed the seam. The key to this is installing the wood frame so that everything fits nice. the wood frame came from Snyder's Antiques. Again really expensive, I think $600, but a must IMO.
Old 03-19-2013, 10:23 AM
ok this time I will actually upload the pics. sorry
ID:	72388   Click image for larger version
ID:	72389   Click image for larger version
Old 04-01-2013, 11:17 PM
roof dimensions
I nee to find out the roof opening dimensions on my 32 ford 5 window coupe but the car isn't here for me to take measurements its at the powder coaters any answer would help I need to order some stuff be fore the car gets back to me
Old 04-02-2013, 06:43 AM
I purchased my roof panel from Howell's sheet metal. Fordor.com They might have the dimensions on their site. Unfortunately i can not recommend them. They are expensive and their service is horrible. They always tell you they have it in stock and then it is weeks before you get it. When you do get it the freight charges which they do not give you when you buy them is ridiculous. I would go to a junk yard and cut the roof off of a mini van. Then bring it back and trim to fit. The roof I purchased had to be trimmed anyways so it was the same amount of work. Just use a jig saw and it goes fast.
Want to swap roofs 62galaxiguy Body - Exterior 5 12-07-2005 01:24 PM
How are pre-1940 roofs insulated for sound and heat? jpd37 Interior 6 10-10-2005 01:09 PM
