Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - The Roofus Special
  #142 (permalink)
Old 12-25-2009, 09:54 AM
Flipper_1938's Avatar
Flipper_1938 Flipper_1938 is offline
And started on my front suspension.
I found a pretty cool raw material in the junk pile....Uni-strut. I like the factory punched, ebenly spaced oval lightening holes. I cut it down to 1 1/2 x 3/4 channel.
The round tubes that hold the bushings are tractor link bushings from TSC.
The tapered hole for the lower ball joint is from the jaguar parts car.
Way more work than I thought it would be. with all of the trial and error, it took two days for me to figure the first one out.
First I-beam
donor tapered hole
With tapered hole installed
Turning it into an a-arm
