Hi,the build is looking good,i think i would make 3 reverse scoops to cover the rack,and tie rod ends.you could either weld them in,or make them up,cut the head off of an 1/8 inch bolt,weld bolt to scoop,drill maybe 3 holes for each scoop in the crossmember,then bolt the scoops in...but youre looking good the way you are......
