Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - The Roofus Special
  #234 (permalink)
Old 09-06-2010, 08:43 PM
Flipper_1938's Avatar
Flipper_1938 Flipper_1938 is offline
Same thing on the other side.
Now to start fabbing up the straps.
I started on the end that I just made the bases.
The other end of the straps will be secured by nuts and bolts through the flange of the crossmember.
just connect the dots.
...and then gusset the hell out of it so that the bends in the straps stay where they are supposed to be.
Other clamp done. Guset was done differently (clamp on this side is farther outboard...less ground clearance), but should be plenty beefy.
Boots look like crap.
But they are necessary
The spring should block out most of the view
Oh yeah, the u-bolts I bought were too small. They won't work
