Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - The Roofus Special
  #240 (permalink)
Old 10-08-2010, 01:34 AM
Flipper_1938's Avatar
Flipper_1938 Flipper_1938 is offline
Looks like I am going to get to work on the car this weekend. Not 100% sure what the next step should be.
I'm guessing that it should be to permanently mount the front crossmember and mount lower control arms. Once the arms are set, I should be able to plant my shackle hangers in the right spot.
That will probably tie up the whole weekend. If it doesn't, I will try and nail down the design for motor mounts and the path for the steering shaft....right now they look like they will be competing for the same space. I probably need to figure that out be fore I move to the upper control arm fab process.
