The Roofus Special - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #46 (permalink)
Old 05-10-2009, 07:10 PM
Flipper_1938's Avatar
I got my other spring box put together and started looking at how to anchor the top links and came to the conclusion that I needed more beef in my framework. I am adding some 1.5 x 1.5 front to back in a more conventional frame like position. I am also installed a 1.5 x 1.5 crossmember ahead of the forward spring support to provide additional support for the front of the spring. There will still be an angle added from the link mount to the front back tube.
This about where I thought I was going to get to last weekend.
I feel a lot more comfortable with the extra beef.
Since I am not sure exactly what spring rate I have, I build some adjustability in for the top links.
  #47 (permalink)
Old 05-11-2009, 05:04 AM
Next weekend, I will add a diagonal for the link mounts and mount the spring boxes (verticle wall at back, angled wall at front and tied to the frame sideways down low).
Hopefully after that, the pace will pick back up.
  #48 (permalink)
Old 05-25-2009, 06:04 PM
Here are the pics of the boxes getting welded in.
The link mount needs support. I will also tie the boxes in to these.
Stuff is too crowded to get to all seams. I cut the tube apart. Some of the welds are on the inside. After these welds are done, the tube gets put back together. Fun!
  #49 (permalink)
Old 05-25-2009, 06:05 PM
Tubes put back together
Boxes tied to the diagonal
Pics of loading the suspension
  #50 (permalink)
1952 Mercedes gas tank looks like it will work for this car.
It should clear the links OK and has a little bit of clearance for the diff. Fuel inlet will work with a racecar style cap on the top of the boattail.
  #51 (permalink)
Old 05-25-2009, 06:06 PM
This is where I ended the day. I plated in the opening above the boxes. I feels really solid.
  #52 (permalink)
With any luck, I will re-hang the rear quarters and decide on what the next build step.
Not sure exactly what to do next.
I think I need to start the rearmost frame section/trunk floor. I think I need to start the upwards taper of the boattail at the rear axle...similar to this car.
  #53 (permalink)
Old 05-25-2009, 06:07 PM
Today was a fun day. I finished up a little welding on the passenger side spring box and then started trying to mount the body side.
It was more difficult than last time. There is an axle there.
I started by mocking the body up on top of the axle and blocks of wood to see where stuff lined up.
I am glad that I thought to draw a reference line last time it was mocked up.
First set of dimensions....end cut out was WAY different.
  #54 (permalink)
The first cuts were barely a good starting point. I am glad I started slow and snuck up on the shape. The axle moves rearward as it compresses.....really moves rearward! That parking brake cable was kind of a pain too.
Lots of jacking and drawing, then triming and re-instalation.
Final shape. I think.
  #55 (permalink)
Old 05-25-2009, 06:08 PM
I know the tail sticks way out there and will drag everything, but I can not make myself cut the heck out of it for clearance. I think I am just going to beef up the tail so it can handle being dragged. I may even add a caster back there.
Here is the current idea. Slight sweep with a radius at the bottom.
Right now the whole back end is an almost clean sheet to work with
Playing with cop car roll bars and a harbor freight pipe bender
  #56 (permalink)
Old 05-25-2009, 06:09 PM
I trimmed the tube. kinda hard to do just by eyeballing it. Still needs a little fine tuning....but I think it will work.
Close enough that I made another one for the other side.
  #57 (permalink)
The new rear frame rails will be on the same level as the current 1x1. I just haven't cut out the old stuff yet.
  #58 (permalink)
Old 05-25-2009, 06:10 PM
I am using more cop car roll bar parts to complete the rear frame rails. Using a couple of bends, I will be able to clear the shock mounts and tie into the 1.5 x 1.5 that runs below the upper link mounts. The joint will be mitered.
This will also gime me a "crumple zone" for the rear frame rails. Heaven forbid I take a hit or spin out in it, the 90 degree bends should fold.
  #59 (permalink)
Old 05-27-2009, 05:11 AM
Any thoughts on the round tube in the tail section? Keep it? Trash it?
I am a little concearned about making the tail end so rigid. Should I be?
  #60 (permalink)
Old 05-27-2009, 03:02 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
You'll need some support for the sheet metal for sure.
My vote would be to keep it.
Super Chevy Magazine Special Nova Edition noviac Hotrodders' Lounge 6 01-05-2011 08:28 PM
Special Editions, Limited Editions pasadenahotrod Hotrodders' Lounge 10 01-06-2007 12:12 PM
72 camper special ap0001 Hotrodding Basics 3 01-24-2005 04:44 PM
Special Order Paint from the Factory in 1968 - Records KristensRanchero Body - Exterior 4 09-18-2004 10:20 AM
narrow control arms or special wheels? 54 Chevy Suspension - Brakes - Steering 2 02-07-2003 11:32 AM
