Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - The Roofus Special
  #377 (permalink)
Old 12-08-2012, 09:55 AM
Flipper_1938's Avatar
Flipper_1938 Flipper_1938 is offline
Originally Posted by boatbob2 View Post
I love that you have the energy,and gumption to see this car finished,I only have 1 suggestion,on the upper edges of the red panel,and the panel to its rear,i would take a section of large brake line,and using a cutting wheel,put a cut thru it length ways,then force the tube,down over those upper edges,and weld the tube into place,much finished look...
The body panels are still in the mock-up phase. The plan is to weld everything together and "box in" the cockpit like a 20's-30's roadster.
There will be inner body panels and a 1-2" ledge at the top that seperates the inner and outer panels
