rookie needs help - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2002, 03:03 PM
47dawg's Avatar
Post rookie needs help
hey new mwmber here,im working on a 47 dodge pu with a camero clip,350ci370hp. this is my first rod project. any suggestions on a manual transmission,also id like to know if im going to have to replace the rearend. im pretty sure its oe.i have enjoyed browsing through ur bulletin board the last couple of weeks,nice job.
[ November 07, 2002: Message edited by: 47dawg ]</p>
Old 11-07-2002, 03:14 PM
woodz428's Avatar
Troll Hunter
Arrow
The rearend will have to go sooner or later, so I'd change it now, that way you can get common F/R bolt patterns at the same time.
Old 11-07-2002, 04:40 PM
BOBCRMAN@aol.com's Avatar
Post
put an s-truck rear end in it 2-whl drive they work like they were made for it.
Old 11-07-2002, 06:31 PM
47dawg's Avatar
Post
thx for the info,know where i can get a muncie to go in between
Old 11-09-2002, 03:37 PM
DJM DJM is offline
New Member
Post
Good Luck on your project. Try Ebay under parts 4-speeds..several listed now. Pretty expensive if your on a budget. Sagnaw will work and a lot cheaper.
