Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Room for a speedo-cable on Muncie M20?
Old 04-15-2013, 01:27 PM
31ROC's Avatar
31ROC 31ROC is offline
Some of the early cruise contols actually worked off of a drive mounted on the firewall. The speedo cable went to the firewall to the cruise adapter and then from the firewall to the speedo. Bottom line is your idea should work fine.
Sounds good, gotta come up with some sort of bracket to mount that conversion "gizmo type adapter thing".........
