Room for a speedo-cable on Muncie M20? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2013, 04:11 AM
31ROC's Avatar
So, nearing completion of the tranny swap-(700R4 to Muncie M20). I currently have an electric speedometer, and the Muncie takes a mechanical cable. Just install the conversion kit right? So I bought one, and there's no room to fit it between the shift linkage. In fact, being a newbie at this, is there really any room for a mechanical cable? (Do I need to change the speedo to a mechanical?)
See attached photos.....
ID:	73214   Click image for larger version
Old 04-15-2013, 08:02 AM
RWENUTS's Avatar
I've used offset ratio adaptors to miss linkage before. They make 90* ones too. MIght find something here that would work.
Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4
Old 04-15-2013, 08:03 AM
My knowledge here is very limited but I do know the pontiac speedo drive was on the passenger side of the tailshaft. Worse case scenario you could swap tailshaft housings. I am sure there is an easier solution but thought I would share that.
Old 04-15-2013, 09:21 AM
31ROC's Avatar
Thanks for the suggestions guys.
I am thinking I can attach a short mechanical cable (I hope I can get it in there between linkage), then install the convertor on the other end of the cable, which will enable me to run a wire to the electric speedo?
If so, just need to figure a way to support/mount the short cable/convertor assembly.....
Old 04-15-2013, 12:14 PM
Some of the early cruise contols actually worked off of a drive mounted on the firewall. The speedo cable went to the firewall to the cruise adapter and then from the firewall to the speedo. Bottom line is your idea should work fine.
Old 04-15-2013, 01:27 PM
31ROC's Avatar
Sounds good, gotta come up with some sort of bracket to mount that conversion "gizmo type adapter thing".........
Muncie M20 linkage placement mmisch Transmission - Rearend 2 02-08-2010 04:33 PM
Muncie M20 Won't go into first gear zeromod Transmission - Rearend 3 05-03-2009 05:29 PM
muncie m20 350sblock Transmission - Rearend 5 05-08-2008 02:40 AM
trying to decode my muncie M20 TCAMARO Transmission - Rearend 1 05-12-2005 04:55 PM
Muncie M20 Input shaft deflection RogP Transmission - Rearend 6 08-21-2004 09:42 PM
