Rootlieb hood on a glass car .... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2011, 01:02 PM
Mayor of G-Vegas's Avatar
I just ordered a Rootlieb 4 piece hood for my glass 32 Deuce Roadster . Im running a steel Vintique shell . Anybody out there have any tips or tricks on installing one of these on a glass car. Never worked with one of these hoods before - Thanks Mayor
Old 08-11-2011, 01:48 PM
302 Z28's Avatar
Plan on grinding the edges to obtain a consistant gap on a glass car.
Vince
Old 08-11-2011, 03:32 PM
Irelands child's Avatar
Vince - grind the edges?? You'll lose the rolled over doubled edge and the strength or do you weld them afterwards - which means more welding. And grinding. And welding. etc. Wouldn't you grind/fit the 'glass body instead? If you make an error, it's a lot easier fixing 'glass then trying to repair a $250+ steel hood side (you don't want to know how I know that price and I'm not even using them) Of course you do all that after doing a body alignment with frame shimming first
Dave W
Irelands child
Old 08-11-2011, 05:06 PM
302 Z28's Avatar
My Rootlieb hood did not have rolled edges, flat sheet metal is all.
Vince
Old 08-11-2011, 05:36 PM
Vince
I guess that would make it a bit easier to do some fitting. Sure would have made my life 'better' when I did my hood - at least the tops that I am using
Dave W
Irelands child
Old 08-11-2011, 05:41 PM
302 Z28's Avatar
Originally Posted by Irelands child
I guess that would make it a bit easier to do some fitting. Sure would have mde my life 'better' when I did my hood - at least th tops that I am using
Dave W
The only area of my hood that has a rolled edge is where it contacts the inner fender panels, the rest is just flat panel steel. I had to grind both the top on either side of center and also both sides. That was a lot easier that trying to reproduce the edge of the glass body after grinding on it. If you look at that first photo you can see the red line that I had to remove.
Vince
Future problems with glass hood? panelwagon62 Body - Exterior 7 08-15-2010 03:26 PM
section a rootlieb hood powerrodsmike Body - Exterior 27 07-30-2006 02:16 PM
Making a 'glass hood S10xGN Body - Exterior 1 02-22-2006 12:42 PM
Glass hood for 46 Chevy Truck? Trim-man Body - Exterior 5 06-17-2004 06:26 PM
fiber glass hood 409guy Body - Exterior 15 10-27-2002 07:26 AM
