Roots style blower for daily use? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2013, 09:08 PM
I am considering a 500 BBF with a roots style blower for my '73 Mach-1. The engine I am considering is a 460 stroked to 500 inches, about 8.25:1 compression, Kaase P-51 heads, and around 240/248 @ .050.
I will have a built 9" rear with 3.50 gears.
First, can I run a roots blower and have it daily driveable? If so, would yoy recommend the 6-71 or an 8-71? I was thinking of BDS because they offer an after cooler.
Thanks everyone. ...
Old 07-28-2013, 11:45 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Aftercooler?
As far as a blown DD, there are several members here who do, bentwings even drives his Willys in the winter, I drove my 8-71 383 Nova as a DD in the summer in Alaska. I'd definitely do 8-71 for a 500 inch motor. The build is critical to longevity, do your homework first.
Semper Fi
Old 07-29-2013, 12:13 AM
I have had a supercharged car before. An EFI 393W with a Vortech. But never a carbureted setup. I am certainly going to go forged internals. Is there anything else I should consider or look for?
Old 07-29-2013, 12:21 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
If you're boost smart you probably know the basics, c.r. requirements, internals, cam profiles, clearances, etc. There's a lot to know, but you just need to ask questions if you have specific concerns.
Semper Fi
Old 07-29-2013, 01:27 AM
As far as compression goes, I figure 8-8.5 (I'm aiming for just about 8.25), aluminum heads, and for a cam (240/248 with moderate lift and a 114' LSA) . I planning on a big aluminum radiator with dual electric fans and an external oil cooler.
What kind of boost can I run with 91 octane? I figured around 10lbs.
Old 07-29-2013, 08:50 AM
39 chev's Avatar
Last journal entry: new pictures of T-bucket
Not exactly daily drivers,but I have been running GMC blowers on basicly stock street engines for 30+ years.Lots of highway miles.pulling a camper,tow dollying project cars around,etc.etc. absolutely no reason why you couldn't use as a daily driver.
Old 07-29-2013, 09:55 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Even though you wouldn't be in boost full time, 10 pounds is a lot of boost for a roots blower on the street! With a static c.r. of 8.5, at 10 pounds of boost your effective c.r. will be 14.3:1, pushing it for pump gas. You should seriously consider a meth/water injection system and BTM to pull timing related to boost. I use an AIS injection system.
Semper Fi
Old 07-29-2013, 03:49 PM
Wow. Thanks. I just figured the stroker because its not really more (cost) since I'm using forged parts anyways. And I was thinking 8lbs because its what I ran in my efi motor with the Vortech.
Old 07-29-2013, 07:50 PM
NOlowrider's Avatar
US Navy-Retired
I agree with everything above, however the only draw back (for me) is gas mileage. Mine sucks. BBC 6/71 with two 750DP. But I didn't build it to conserve gas and help the nations fuel dependence. I build it to haul ***.
roots 3-71 blower prumora1 Engine 1 02-23-2013 04:23 AM
Roots Blower War Horse Engine 8 06-25-2012 05:27 PM
455 hellbent for an old roots style blower Spiders Engine 7 04-05-2010 03:30 AM
A roots style blower that runs on blow thru carbs? Jared Engine 6 01-28-2005 05:50 PM
ROOTS BLOWER scott011422 Engine 1 05-19-2003 01:57 PM
